daily use boosted for d-series
dear all
want to ask,
i have d16 vtec
if i want to put turbo kit on my d16 for daily use,
what kind recomended turbokit / hybrid for my d16.
the boost are sets on 0,5-1bar
what kind low comp piston that i can use i hear that vitara is it right?
do i have oversize linear block?
i hope i can get output 200-250hp on wheel for this setup.
thanks
want to ask,
i have d16 vtec
thanks
I never narc'd on nobody!
Re: daily use boosted for d-series
A TD04H-15G or a GT2860RS could easily get you to 200WHP on a healthy engine, without having to open the block up. For Daily driving, I wouldn't run lowered compression - it'll only serve to kill your power out of boost, making a sluggish econobox even worse.
p2p0.org makes a custom length rod to run with vitara pistons to make up for slow spool time and I assume it would also make driveability out of boost more viable as well.
It's wU to the sOLdiEr!
OP
Go though this a few times
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
dear all thanks for the advice
want to ask if i put GT2558R do i get the out put on 200-250,
do you have several option same as gt2558r with ball bearing.
Who is Mr Robot?
you'd need at least a gt28 turbine side to make the power you want and that's only if you go gt series, don't even start with the other turbo options.
WakeSpliter
10-06-2003 01:22 PM
