opinions on throttle body
Hey ht I'm shopping around for a new throttle body. My last throttle body i had was a bdl. It was getting stuck open so i trashed it. I did some research and from what i found a while ago people said to go skunk2 . But which one from skunk2? Pro series, alpha? I'm also open to other brands .
Re: opinions on throttle body
Alpha 66mm here, work like a charm. I'm not lie to you when say my gas pedal now is more easy than my 06 Altima. Zero stuck or issues.
P.S. The only issue was when I received it, not coming with the s/s bolts and the ones included are to longs, but $8 in the local bolt shop and fixed.
DO IT ON ALL FOURS
Are you just wanting a brand reference or size recommendation? Any more brand doesn't really matter as much as long as it has a brass plate in it and bushings/bearings that don't wear quickly.
Who is Mr Robot?
https://honda-tech.com/forums/forced-induction-49/%2499-throttle-bodys-%7C-4-3-2-5-bar-hondata-omnipower-map-sensors-3101207/
that's the throttle body I would use. they've had nothing but great results with them and they are the same quality or better than similar offerings.
plus you're supporting a company that not only devotes itself to our hobby but supports this site as well
I plan on getting one when I start my accord f22a1 turbo build.
https://honda-tech.com/forums/showthread.php?t=3101207
im really happy with my alpha 70mm. doesnt get stuck open or closed. easy goin throttle spring. way better than the pp i had back in the day
Buddy's skunk2 stuck open...we spun the spring so there would be more tension to close. Never had any issues after that. I personally have a Blox. Never had any issues.
Moderator
I preferred the Skunk2 Alpha series because of the fact that it has a nice fine idle screw like the OEM. It made a real difference in case you change to aftermarket camshafts in which the change in vacuum would lower idle to where even the throttle plate adjustment may not be enough. I'm not so much of a fan of the Billet Pro Series models because of the sticking issues that they've experienced in past , which shawty22 might be referring to.
Yeah from my searching, I found people like the alpha skunk2 . But is it that much better then the omni one? Or the one want boost mentioned. I've also heard good things about the omni throttle body.
word.....have countless cars on the dyno with the tb with zero issues.
skunk2 i've seen a few do stick, not all
blox, i've seen 2 with manufacture defects, the tps "tab" is off center of tb, so tps signal is off.
I also cleaned up my throttle cable some and things work like a charm now.
