200 hp boosted ls reliability?
Old Dec 15, 2013 | 11:16 AM
No_jdm_fanboys's Avatar
Default 200 hp boosted ls reliability?
Hey guys been doin some research haven't found much on this subject I'm wanting some mild power gains out of my fresh rebuilt ls (91 bottom end 95 top end) 250hp is the top that I want since I don't smash on my car all that often. My question is with regular maintenance can I see my motor go to 100,000 mi plus with out any major mechanical failures ex. Spun bearings, thrown rods, dropped valves etc. I plan on keeping the stock rev limits and everything since my car never sees redline anyway. Thoughts? Kit recommendations? I have a very competent mechanic to do the install
Old Dec 15, 2013 | 11:32 AM
2kdrift's Avatar
Default Re: 200 hp boosted ls reliability?
100k miles is a long time but should be fine with a proper tune, for 200-250hp look at the go autoworks street kit
Old Dec 15, 2013 | 12:56 PM
sir.rexington's Avatar
Yup you'll be alright with proper tune and good turbo. Try to get water cooled turbo and intercooler and turbo timer.
Old Dec 16, 2013 | 08:48 AM
Oh ya plan on spending at the very least $1500 on set up and install if not more I'm pretty OCD about making sure regular maintenance stays done and up to date. I drive my car a lot but like I said it rarely sees over 5500 rpm and never touches redline. I just want something that's gonna be reliable but also fun to drive
Old Dec 16, 2013 | 09:07 AM
Balor_Gr's Avatar
Garrett T3 60trim himni-racing sells them 616$
440cc injectors
cast iron manifold
Genuine tial/precision/turbosmart 38mm wastegate.
Intercooler kit
Walbro 255 fuel pump.
Oil feed/return kit.
And get the bov you like the sound.
ECU TUNE.
Old Dec 16, 2013 | 09:18 AM
For sure sounds like a good set up. Is it possible to run that stuff and have the car relatively quiet I.e not sounding like car has an angry beehive under the hood? I'd like it quiet until upper rpm/boost levels wanting the car to be a mild sleeper already have every country bumpkin in a lifted Chevy trying to race and all I wanna do is have fun. Thanks btw for all the info so with all that plus tune I'm probably lookin at more like 2000-2500?
Old Dec 16, 2013 | 09:34 AM
Freemananana's Avatar
Yes, probably more in the $2000 range. 200 HP is definitely low enough to be fairly reliable. That coupled with quality equipment should give you longevity. If you want quite, I believe you should be able to get that with a decent size exhaust and some muffling equipment. A resonator and a muffler should be enough. Turbos tend to quiet it all down.
Old Dec 16, 2013 | 10:27 AM
Sweet thanks for all the info guys now to save my pennies and nickels lol I don't usually skimp on stuff when it comes to my car so quality will be #1 on my list me mechanic quoted me around $2200 with install and a light tune just checkin his numbers
Old Dec 16, 2013 | 10:44 AM
kyden's Avatar
what the heck is a light tune?
Old Dec 16, 2013 | 10:59 AM
Probably some BS base map. I wouldn't get it tuned by your mechanic. I could probably tune it better than what you'd get.
Old Dec 16, 2013 | 03:02 PM
I was gonna budget to have it tuned on a dyno by a reputable shop in Portland since that is the closest place with a decent speed shop but who knows and by "light tune" I ment nothing too aggressive as far as boost levels just wanna be able to get it tuned and be done with it so I can daily drive it. Sorry I couldn't get the right terminology
Old Dec 16, 2013 | 03:35 PM
EpHatchy's Avatar
if your in Oregon look up T-REV MOTORSPORTS in Salem. think hes even a member here.
Old Dec 16, 2013 | 03:43 PM
I will man I am in Oregon
Old Dec 16, 2013 | 05:48 PM
yungkhmer's Avatar
200hp boosted isn't fun. Lol but good luck. Trever at t revs is a cool dude hit him up.
Old Dec 16, 2013 | 07:06 PM
boosted94gsr's Avatar
I would also recomend T-REV in salem too. I hear nothing but good about him and his prices are very fair. I'm having him tune my setup when its ready.
Old Dec 16, 2013 | 09:31 PM
For sure I wanna try and stay with stock internals can anyone recommend a good kit ? Been reading that my stock ls block can handle up to 300hp anybody have experience with this and the motor actually surviving
Old Dec 17, 2013 | 01:17 AM
frost_white_ej1's Avatar
this topic has been discuss quite often already! we seen quite a few high number on a stock setup that is reliable and some not so promising, it all in the tune, the quality of the part your using, how healty your motor is, and was it properly assemble.
Old Dec 17, 2013 | 12:41 PM
Motor is freshly rebuilt 9k ago when turbo is installed I'll be putting a new head gasket and head studs (ARP) get it tuned on a dyno I'm just wanting a fun daily to drive that has more get up and go then stock. I like having power but want it to last as well for sure won't be cutting corners I'm the type that is either do it right or don't do it
Old Dec 18, 2013 | 12:33 PM
Schister66's Avatar
Man U FTW
Sounds like you've got it...do it right, once
Old Dec 20, 2013 | 09:54 AM
b20ricepower's Avatar
You wont need arp head studs and a new head gasket for those power levels. Save your money and get a quality turbo setup/tune.
Old Dec 20, 2013 | 06:01 PM
blackeg's Avatar
at 240whp and and a quick uberdata dyno tune (back in '04 lol) my 190k mile ls survived quite a lot of mishaps. anything from thermostat stuck closed on a 150 mile highway drive to bad wideband and running afr's in boost close to 14:1. i daily drove it for close to 2 years, probably 30-40k miles. took it out to go vtec, still had 170ish psi compression.
cliffs: with any kind of reasonable tune and a healthy motor to start it will last quite a while
hayden187
Dec 18, 2010 09:52 AM
92hatchattack
35
Jun 2, 2005 06:01 PM
awdriscol4
Dec 7, 2004 01:03 PM
drewbie*
Jun 18, 2004 01:25 PM
spoonb18b
Jul 2, 2003 07:40 AM
