b18b turbo cams
Old 01-02-2014, 04:59 AM
08yfzrider's Avatar
Default b18b turbo cams
Im currently running the brian crower 0021 turbo cams in my ls. I have been looking for a bigger cam but cant seem to find anything bigger except for all motor applications. Does anyone make a bigger turbo cam for the ls?
Old 01-02-2014, 05:53 AM
kyden's Avatar
Default Re: b18b turbo cams
use an n/a cam. bc stage 2 or even the crower 403. however, do not use a cast/log style manifold with it.
Old 01-02-2014, 06:32 AM
Mattb16teg's Avatar
^ I agree with that! And def no long manifold, you need something that will not restrict or bottle neck exhaust flow to utilize those cams. Something equal length like a ram horn or top mount would be ideal.
Old 01-02-2014, 11:10 AM
Man U FTW
Schister66's Avatar
**Moved to Forced Induction**
Old 01-02-2014, 11:11 AM
Man U FTW
Schister66's Avatar
Can you tell us more about the setup...especially which turbo and fuel you're running as well as your power goal. Cam choices aren't as cut-and-dry as people tend to think
Old 01-02-2014, 11:15 AM
Moderator
TheShodan's Avatar
Nor are the manifold choices that may or may not go with it.
Check here.
https://honda-tech.com/forums/forced-induction-16/why-top-mount-2152865/
"log manifold" is a very subjective term on this forum, so show care.
It may be that cams may not be necessary at all, depending upon power goal and purpose.
Old 01-02-2014, 11:18 AM
Man U FTW
Schister66's Avatar
I dont know if you're opposed to the idea, but an LS/VTEC conversion is another viable option and would probably cost similar to the cams
Old 01-04-2014, 07:43 AM
Who is Mr Robot?
wantboost's Avatar
talk to user DDTECH. he can do cams for an LS without issue, tailormade to fit your setup. just tell him wantboost sent you and he'll help you out. best way is to PM him.
Old 01-05-2014, 06:47 PM
DDTECH's Avatar
Zing!.. Bigger isn't always better.
It will STRONGLY depend on turbo manifold used as well.
Old 01-05-2014, 08:52 PM
m4xwellmurd3r's Avatar
Depending on your power goals, crower 403s might be a good fit. Theyre similar to the jge303 cams I have, and I know for sure that theyre killer turbo cams.
auto-accessories-inc.
07-27-2007 12:19 PM
fitbmx86
06-14-2007 05:03 PM
justint
06-11-2006 10:19 AM
Jared
03-24-2003 04:38 PM
InfamousRS
12-08-2001 05:54 PM
Quick Reply: b18b turbo cams
