ls vtec turbo won't rev choking and sputter
hi guys like tittle say, my civic recently start to sputter when press the gas cold. Now it idle all day long perfect but a soon as press the gas chokes and die and if you play with the throttle slowly revs. When the choke and sputtering happen the wideband goes completely to lean.
I take off the charge pipe, put a stock fuel pump, injectors, Map sensor and a base map, send the ECU to check and the same thing. I already put the aftermarket equipment again with a few new things and nothing.
Bad gas or contaminated tank can cause this? I'm out of ideas!!
Re: ls vtec turbo won't rev choking and sputter
This was my first suspect, I bought a new king dizzy and put OEM cap, rotor,
new plugs and the wires are like 6 months NGK HE64.
Also I put new walbro 255, new AEM FPR, fuel filter, main relay, ECT, TPS and bench test the injectors. I checked the time like 20 times and is dead spot. No CEL, Alternator charge is 14.05 at idle. Cleaned all the grounds and added a new one to be sure.
The compression is 200 across the board with 9.0:1
Really I'm lost
Really I'm lost
TruEM1
12-10-2013 08:52 PM
lopezchris21
15
06-13-2012 12:25 PM
Jeanious
08-31-2010 11:37 AM
