Boostlsveg's 92 cx street/strip build thread
Alright guys I've had a build thread in the appearance build section for awhile now documenting this build but I figured I would put one in here now since it is nearing completion. My goal for the car is to run real low 10s possibly high 9s this season. I plan to pretty much max the turbo out on e85 hoping for around 725 -750 whp. The car will b tuned by a friend of mine Derek (d-rob) @ IMW in Carlisle. My setup will consist of:
Short block:
99' gsr block golden eagle sleeved and oringed
Ls crank
Manley turbo tuff I beams
JE pistons 84.5 mm ~9.4-1 got this shortblock used from a guy on here with ~1000 miles on it.
Oem honda bearing
Oem gsr /itr oil pump w/toda gear
Oem timing belt
Arp head studs
GE head gasket
Ati race damper
Hasport mounts
Head:
I have an itr head which I had new guides,seals n valve job done on that I was planning to use but due to me being a bonehead n giving the guy the wrong caps when I sold my other head I now cannot use (sent him the caps I had, never received the ones I needed from him :/ ). So now I got another b16 head yesterday which I will have the same done on once my car gets back from getting the cage put in cuz I'm gonna leave this head bolted up while it's out there and I need this valvetrain.
Skunk2 pro series springs n titanium retainers
Supertech black nitrate flat face std sizevalves
Oem prelude spring style lmas with a shim
Supertech keepers
Skunk2 pro 1s and pro series cam gears
Turbo setup:
Afi top mount wrapped in dei exhaust wrap
Tial 44 wastegate
Tial bov
Precision 6265 .82 ar t3
Precision 750 intercooler
Cx 3" ic piping fab'd by me welded by d-rob
Not sure yet if I'm going with an up pipe setup or a pass side exit. Was planning on routing it out the drivers side but now I realize I'm not gonna b able to do that.
Ignition setup is stock with msd wires but that will change I just haven't decided exactly what I'm gonna go with yet.
Fuel setup:
ID 2000s
GE fuel rail
-8 an feed stock feed used as return, same as -6 basically
New tank
Aeromotive fpr
Victor x im
Blox 74mm tb
Speedfactory 4bar map
Hondata s300 with BBG
Defi blueracer gauges- boost,water temp, n oil pressure
Autometer cobalt tach
Still need to pick up an innovative lc2 wideband
Still need to pick up a pump. Plan is a walbro 450 -already ran 8awg and 50 amp relay for this but I'm thinking about picking up a dual pump hanger if I can find one for the right price.
Fuel lab 10 micron filter
Also have a go-autoworks rad and fan shroud
Spal 13" hp fan
Bwr catch can
Go-autoworks clutch line
Omnipower coilovers
Gonna get strange rears for the track
Kirkey race seat
Gforce harness
Comp twin disc
Stock axles for now
Tilton flow control valve
Gsr trans with mfactory LSD and ls fd gearset will b heat treated which I still need to send out so for now I'm putting in my stock gsr spare which works out cuz then I'll know whether this one needs any work or not.
Got ssr comp 15x6.5 these weigh like 8 lbs
M&H street/strip bias ply 235/60 gonna try hard to get into the tens on these on high boost
Also got some welds coming here shortly
Will b most likely running 24.5x9.5 but not sure I might try the 25x8.7 either way m&h racemasters
Car will b painted this year but that is the very last thing on my list of things to do.
Now for a $hit ton of pics lol
Sorry about these pics being out of order btw.
Let me know what u guys think! Mike
Short block:
Ls crank
Oem honda bearing
Oem timing belt
Arp head studs
GE head gasket
Ati race damper
Hasport mounts
Head:
Supertech keepers
Turbo setup:
Tial 44 wastegate
Tial bov
Fuel setup:
ID 2000s
GE fuel rail
New tank
Aeromotive fpr
Victor x im
Blox 74mm tb
Spal 13" hp fan
Bwr catch can
Omnipower coilovers
Kirkey race seat
Gforce harness
Comp twin disc
Stock axles for now
thanks man I hope so too! Honestly tho when I started this build I was only looking for 650 so I'd b happy with that, but I've since gotten a lil greedy n decided well just max it out n c what it can make. Lol
Trying to decide between a fastline shifter and a k tuned shifter. Suggestions? Wasn't planning on getting a diff one but it appears that with the rib guards on this kirkey seat I will need a taller shifter. I like the fact that the k tuned one is adjustable, just not sure about the height. How tall is it compared to the fastline? Thanks for any help. Mike
So I received my shroud today n at first glance it looks like I'm not even gonna b able to use it as the fan is bigger than the damn shroud. Lol I'll have to get into it more this week sometime and c if I'll b able to make it work. I doubt I'm gonna b able to tho. I was thinking I would b able to cut the hole bigger n drill new holes but it's not gonna work out that way I don't think. It is a nice piece tho n it will bolt nicely to the rad.
Re: Boostlsveg's 92 cx street/strip build thread
I spent $400 on the t1 shroud and spal fan combo just to find out it dosent fit with my current intercooler piping.
I've decided to switch to a spall medi profile (2.5 thick) push fan
This frees up a lot of room.
Thanks for the info. I don't have that problem cuz I routed my piping up threw the stock intake hole. I think I'm just gonna mount mine directly on the rad since it basically covers the whole rad anyways I don't really think the shroud will b necessary.
Got my shifter the other day! Also a pic of the car stripped back down, motor pulled on the way to 4130 fab for a 10pt cage! Btw those guys r cool out there! Shop is legit as **** n real down to earth guys, n his personal car is real bada$$! Thanks to the guys that recommended I go there!
Got my welds today! They r sweet! Can't wait to throw some slicks on them. Question for u guys that do rim screws, how far in from the outer lip do they normally go? Also picked up a used afx wideband the other day from a buddy of mine.
Got my head back from the machine shop today. Gonna order a new head gasket n head studs this week so I can I can get the motor back together so as soon as I get the car back it will b ready to drop in.
You have about the same set up as me. I have the pte6265 and i made 764whp with it but had to turn it way down due to not enough fuel at the time. GL with the build. 9's for sure!
Anywho I ended up finding a guy here on HT at the time who sold me his cam cap and so I took the head to Clearwater Cylinderhead in my area and they added weld to the damaged journal and align honed the journal to spec and everything worked just fine for the 3 yrs I ran that motor.....
BTW that's cool your using Bradpenn oil. I don't live in PA but ive been to Bradford PA and have been past their refinery in the middle of Bradford near Zippo
Do you have the bolt sized/thread pitch for this? I bought a clutch inspection plate (that is this, right?) and I don't know what size bolts to use.
Thanks
Also, looks good so far. Hope you achieve the 700 goal. That shifter looks mean haha. What padding are you using with that seat? Looks like it'd be hell for the streets though.
Dude on my first LSV build I bought a bad PR3 head on ebay which looked to be fine from the ad and the pictures but the price was too good to be true. The cam journal at the dizzy had scoring from oil starvation and the cam cap was toast.... Anywho I ended up finding a guy here on HT at the time who sold me his cam cap and so I took the head to Clearwater Cylinderhead in my area and they added weld to the damaged journal and align honed the journal to spec and everything worked just fine for the 3 yrs I ran that motor..... BTW that's cool your using Bradpenn oil. I don't live in PA but ive been to Bradford PA and have been past their refinery in the middle of Bradford near Zippo
Do you have the bolt sized/thread pitch for this? I bought a clutch inspection plate (that is this, right?) and I don't know what size bolts to use. Thanks Also, looks good so far. Hope you achieve the 700 goal. That shifter looks mean haha. What padding are you using with that seat? Looks like it'd be hell for the streets though.
But yeah Bradpenn gets the "Brad" because its another product of Bradford PA where Zippo lighter started out too.....its literally on the boarder of NY. I've been up there twice cause my girls folks use to live there and worked for Zippo otherwise I'd have no clue about it, I know you cant get that stuff iin FL where I live lol.
Thanks
whatever thread pitch honda uses, there either 14 or 17mm head ...cant quite remember and theres also a 10mm head bolt
