Turbo B16 civic
Hey my names Ahmed i drive a 1996 slammed Civic on coilovers I am just dropping in this b16a turboed motor in the car and just about finishing up a hopefully will have it running by spring time probably pushing 7-10 psi max dont know yet about the psi any suggestions?! B16a ARP head studs double layer head gasket , engine has been fully regasketed , 440 dsm injectors pretty sure , walbro fuel pump , got msd ignition and msd coil, vtec controller, boost retard , s300 ecu trying to find a basemap tune atm to get her fired up and take her to a dyno when the snow clears up if anyone has any input that would be great looking to find answers about how much boost is safe to run and is meth injection worth running on a stock motor and any answers that you would think is helpful and any other upgrades you think I should run! Thanks
It's wU to the sOLdiEr!
Re: Turbo B16 civic
what up
not sure what size turbo your running and psi is meaningless. assuming your motor is stock 350whp is max i would run on that motor. get rid of the vtec controller because your s300 will control all of that jazz. the msd isnt needed, should have stay with the stock stuff. some one else here will chime as well
Re: Turbo B16 civic
check make sure your motor is healthy. comression test, leak down test, and check your valve lash. 10psi should keep you in the safe zone. but dont go by psi as stated. dont need the msd or vtec controller, s300 will boss it out
what up not sure what size turbo your running and psi is meaningless. assuming your motor is stock 350whp is max i would run on that motor. get rid of the vtec controller because your s300 will control all of that jazz. the msd isnt needed, should have stay with the stock stuff. some one else here will chime as well
Why isn't the msd needed ? & 280 hp would make me happy so hopefully I can get that goal safely but was just curious what psi would be safe but you said it's meaning less also I won't add the vtec controller
Haven't done a compression tester so I should check that out but it sounded and looks pretty healthy
Re: Turbo B16 civic
because the stock ignition system can handle up to 500 just fine. also, psi is just a number and doesnt mean anything. 10 psi a t3 super 60 is different than 10 psi on gt35. the only thing you should focus on is hp goal and not the number of psi
My turbo is a air research think I should swap it out or what?
Who is Mr Robot?
Re: Turbo B16 civic
without knowing what size turbo you have we can't tell you anything.
I can tell it's a t3/t04e but beyond that it could have any wheel combo in it, you won't make more than 3-5psi in 1st gear so traction isn't an issue there, 2nd will spin if you get on it and other than running a sticky tire like an r888 or a dot drag radial you will have traction issues, unless you don't drive like a jackass all the time lol
also don't be shocked when that eBay "twisted ram" turbo manifold cracks... the material is too thin, of low quality and the welds are **** with almost no penetration. they were notorious (as are all eBay tubular manis) for having the wastegate flange break off, sending your wastegate down the road.
I suggest you inspect the manifold regularly for early signs of cracking around every flange. some even had the turbine inlet flange crack clean off the collector.
Re: Turbo B16 civic
honestly i got a buddy who is helping me out with the turbo build as he just finished building his turboed e30 fully built 2.9 stroker boosted running meth wasted spark etc,
he also told em the air research is a t3 turbo it looks like an ebay turbo and says that upgrading it would be smart due to ebay turbos not lasting but sometimes you get lucky and they do hes current running a holset hx35
as for the hondata so im better off reverting back to stock distributer and wont need any of the boost retard or vtec controller , ill be getting someone to tune it properly on a dyno and probably run 10psi any info on running meth should i or is it not needed for 10 psi
thanks for the help here are a few pics of my buddys car
hes running an MS2 wasted spark
Re: Turbo B16 civic
honestly around 300 flat out i dont want anything crazy just yet i wanna be able to see how the car handles and basically feel the diffrence from stock iv had a frankenstine swapped hatch i got rid of and the thing was hauling *** so atm im just looking to run 300 hp but also be safe without blowing this motor
_Endless_
07-16-2008 01:22 PM
hondastreets1
03-03-2008 09:32 PM
BoostedB16EF8
01-26-2004 03:52 PM
