Downpipe Reduce
Old Feb 11, 2014 | 07:34 PM
Scott53092's Avatar
Default Downpipe Reduce
I am running an hx35, which the exhaust housing has an exhaust port that's 2.5". I am going to run a 3" exhaust out the bumper (forward facing manifold), so I have 2 options for the exhaust.
A. Weld the 3" vband flange straight to othe exhaust housing even though the housing is 2.5" technically
B. Weld a 2.5" to 3" transition diretly to the housing and weld the 3" vband flange to the transition.
Would the sharp change in exhaust size have enough of a negative effect to need the transition?
Old Feb 11, 2014 | 08:12 PM
B and B's Avatar
Loved
Community Favorite
Default Re: Downpipe Reduce
... What I did. H1c.
The flange is .25in bigger on each side.. So the weld almost takes up the space, formed a little contour
Old Feb 12, 2014 | 04:32 AM
hardcore97's Avatar
I got a flange for the holset and my buddy weld a 3" Vband onto it. You should be able to find them on eBay if you wanted to go that route.
Old Feb 12, 2014 | 04:36 AM
hardcore97's Avatar
Or you can message this guy and ask him if he can make one to your specs.
http://bit.ly/1bouox5
Old Feb 12, 2014 | 06:18 AM
Scott53092's Avatar
I have no need to pay anyone, I'm making it all from stainless and tig welding it all. Just trying to figure out if it's worth the tube cost and effort or if it's negligible difference.
Old Feb 12, 2014 | 11:16 AM
wantboost's Avatar
Who is Mr Robot?
I would never weld anything directly to the turbine housing. get a v band flange and do it right.
Old Feb 12, 2014 | 12:54 PM
Furyof4's Avatar
Very common practice to weld a vband flange straight to the housing. Absolutely nothing wrong with that.
pentaq
Welding / Fabrication
22
Feb 2, 2009 08:29 AM
hatchinprogress
Mar 19, 2006 03:17 PM
Vtec92Civic
Oct 20, 2004 02:07 PM
AspectIndustries
Apr 10, 2004 12:23 PM
cjb80
Feb 18, 2003 08:44 AM
