Greddy 18G TD05H Gaskets
Hey guys, I'm finally getting around to putting stuff together for my little turbo build. What gaskets should I purchase for this turbo? I'll need the exhaust manifold which I think I can use an OEM gasket there, the turbo inlet, and the 5 bolt gasket for the elbow, and oil return So mainly 3. Are they the same as T25 and GT series turbo?
Thanks
Thanks
Re: Greddy 18G TD05H Gaskets
Turbine housing gaskets are the same as the GT25/GT28 series, oil return is normal T25. Kinugawa is probably the best option:
http://shopping.kinugawaturbo.com/tu...stainless.aspx
http://shopping.kinugawaturbo.com/tu...nless-2-1.aspx
Who is Mr Robot?
he's correct. turbine housing is a standard Garrett t25/28 unit. uses a t25 inlet gasket and a t25 5 bolt outlet gasket
oil return as previously stated is standard t25, I think a gt series drain flange should fit
use layered stainless steel gaskets like above, not those cheap metal coated paper gaskets.
TravisBiggie
04-19-2012 09:35 PM
BlueShadow
06-23-2005 06:14 PM
redboost10
11-16-2003 07:50 PM
