Tial bov spring help
Old May 15, 2012 | 10:33 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Tial bov spring help
Gettin ready to purchase this bov, just need to know what the spring rate is indicated for and does it matter on which I should get. Thanks!
Oh ya
Should I base the spring rate off hp
Old May 15, 2012 | 10:43 AM
Muckman's Avatar
Moderator in Chief
Default Re: Tial bov spring help
My Tial 50mm bov came with a -7psi spring (black) and I traded it for the -11psi (unpainted) spring. This solved my compressor surge I had at light boost blow off with the black spring.
Old May 15, 2012 | 11:05 AM
TheShodan's Avatar
Moderator
One needs to check their vacuum to determine what size spring is needed.
http://www.tialmedia.com/documents/BOVspc.png
For most hondas -11psi spring is to be used.. (Yes, even if you're running under 10psi of actual boost pressure.. its not based upon the amount of boost pressure you're going to run.)
Old May 15, 2012 | 01:01 PM
Thank you kid sir
1DayIllBFast
Jul 7, 2009 12:27 PM
ctownintegra
Jul 9, 2008 02:41 AM
Nextelbuddy
May 11, 2007 08:42 AM
h22 civic
Jan 30, 2005 12:40 PM
Machine1
Nov 5, 2004 07:13 PM
