d16y8 turbo project help
Old May 9, 2012 | 08:57 AM
mrperformance's Avatar
Default d16y8 turbo project help
Hi guys, I have a new project, is a d16y8 and my setups r:
d16y8 block
vitara piston 75.5
forget rods
acl bearing
port and polish head
stock injectors
h22 throllte
t25 turbo
my question is can I hit 15psi with the stock ecu or i need the p28 setup oh a stanalone, thanks.
Old May 9, 2012 | 08:58 AM
Default Re: d16y8 turbo project help
also have the 3 inch pipe
Old May 11, 2012 | 08:44 PM
civicsi940's Avatar
i personally would get some sort of management to be safe. if you were 5-8psi i would say its pushing it but 15 is like kissing your investment good bye. but thats just IMO
Old May 11, 2012 | 08:49 PM
Dc4LsTeG's Avatar
EK9
I wouldnt boost 1 psi with the stock ecu. Get an EMS and a tune
Old May 11, 2012 | 08:56 PM
civicsi940's Avatar
u can do the apexi controller hack if you dont have the money but i agree with Dc4LsTeG. not only protect your investment but your car too. go safe not sorry. fast and reliable isnt cheap. .....do it proper
Swap'DShuttle's Avatar
Why the hell would you want to run any boost on a stock ecu? Are you just wanting to see how many days it takes to blow that **** up?
Edit: hours or even minutes I should say.
Old May 12, 2012 | 06:15 AM
Bix VT's Avatar
No. Do not use a stock ECU. Please read the Forced Induction Forum FAQ, it should provide you with the answers to your next several questions.
Old May 16, 2012 | 11:47 PM
ok guys I just buy my AEM ems, someone have a map for this setup.
Old May 17, 2012 | 12:11 AM
95civhb's Avatar
before you blow something up, go read the FAQ...
Old May 17, 2012 | 06:45 AM
tron_'s Avatar
10 Year Member
Also don't forget a MAP sensor seeing your factory one will not be able to handle the 15psi you plan on running.
And get bigger injectors. The stock d16 ones are tiny.
Old May 17, 2012 | 10:09 AM
wmac's Avatar
forget rods
no, don't forget the rods!
Old May 17, 2012 | 10:21 AM
kbouchard1092's Avatar
haha yea that could be a problem....the d16y8 is OBD2 ecu therefore yes you will need a OBD1 ecu if you plan on using any type of managment whether it be hondata, ectune,neptune ect.
You will also need a coversion harness to adapt youre OBD2(a or b pending on the year) harness to OBD1. Unless you got AEM which is plug and play. That option would plug right into youre wallet as well tho. A simple chipped OBD1 ecu is youre best bet it does not have to be p28 tho. there are other ecu that will work however, that is the most commonly used.
YOu need to tune the car, so get the Stock ecu or base maps out of youre head right now. Get the car running keep charge pipes disconnected and then tow to youre tuner. if you have to drive there i would use the Stock ecu for the drive there with youre oem injectors (charge disconnected). The tuner can install bigger injectors and get youre management system going.
Old May 17, 2012 | 11:06 AM
EsotericImage's Avatar
Retired Moderator
theres thousands of threads like this already. if you cant get your info from the faqs, then google is your next step
your not putting a flag on the moon here
Old May 17, 2012 | 12:57 PM
boosted_D's Avatar
Your doomed, Take your car to a shop before you blow it up...
Old May 17, 2012 | 01:02 PM
Retired Moderator
Old May 17, 2012 | 02:00 PM
nealnanoHX's Avatar
I saw stock injectors. BIG no no. Get some DSM 450cc injectors at the least. Get a S300, Neptune or AEM EMS for tuning. And dont try tuning it at all yourself, take it to a tuner. Either town it in after the turbo and all supporting components are installed or drive it in with a inter cooler pipe unhooked, the stock injector and ECU that way you can drive it but not get into boost and blow the motor.
Old May 17, 2012 | 03:03 PM
xile6's Avatar
lol. spend money to do the motor and turbo but wants to run stock injectors and ecu. lol
lileghatch
Mar 24, 2009 03:09 PM
sladed16y8
Jan 22, 2007 07:19 PM
ej7d16y5
May 20, 2005 04:37 AM
Turb00HC
May 20, 2004 06:07 PM
