turbo woes
Old Apr 27, 2012 | 04:49 PM
nxtNMkillaB's Avatar
Default turbo woes
hello. i am depressed with turbo woes. i have owned my b16 for about 3 years now.i bought it from h motors and turbod within 1500 miles of install.
now my head is lifting under boost (arp's, cometic, 15 psi.)
a year ago i switched to the arp's and the new headgasket and it has never sealed right since. i milled the head when i did the gasket but not the block. woe is me
now the block is coming out.
i have a question so i dont run into this simple trouble in the future.
when i first got the engine from h motors i noticed the stock clutch was very blue overheated burnt and small cracks. this obviously describes a abused clutch right?
do you think it is possible that the motor was overheated and warped when i bought it.
next motor i get i would like to identify future problems if possible befor they arise.
p.s. car was professionally tuned, and never over heated
Old Apr 27, 2012 | 04:50 PM
Default Re: turbo woes
or maybe i just need a streight edge lol
Old Apr 27, 2012 | 05:02 PM
Whiterice-gsr's Avatar
sounds like a moderately abused clutch to me and i dont think that would point to an overheating issue at all. get rid of the cometic head gasket they're crap. go with oem GE or felpro and give that a shot before u go nuts with the machining.
Old Apr 27, 2012 | 05:56 PM
TheShodan's Avatar
Moderator
Originally Posted by Whiterice-gsr
sounds like a moderately abused clutch to me and i dont think that would point to an overheating issue at all. get rid of the cometic head gasket they're crap. go with oem GE or ****** and give that a shot before u go nuts with the machining.
Nope, you were right, stick with the OEM. Forget that other arbitrary company for a turbo build.
Old Apr 27, 2012 | 08:13 PM
is cometic really crap? i will be checking the deck for warpage befor i machine. thanks for the input. so oem is the way to go? if i end up taking the block out i will buy pistons and rods. should i still use oem head gasket if shooting for 450?
Old Apr 27, 2012 | 08:25 PM
TheShodan's Avatar
Moderator
No. but needs to be prepped a bit differently than OEM. I use one myself on several builds I've done.
Old Apr 28, 2012 | 12:47 PM
there are endless amounnts of ppl who have problems with them, installation error? most likely but oem ones hold up just fine to whatever u can throw at them so why even bother. imo i would try an oem gasket and arp studs torqued properly with an accurate torque wrench before i started machining. when you have it apart a straight edge and some feeler gauges wouldnt be a bad idea just to do a quick check.
Old Apr 28, 2012 | 12:57 PM
rich7777's Avatar
I think Mr Shodan has some kind of trick using RTV/Silicone sealant on the HG.
Old Apr 28, 2012 | 01:32 PM
ya ive heard copper spray and so on, just seems easier to go oem
Old Apr 28, 2012 | 01:34 PM
rich7777's Avatar
Yeah same here, plenty of times. I think TheShodan has another technique though.
Old Apr 28, 2012 | 01:47 PM
probably hes the honda ninja lol.
Old Apr 28, 2012 | 01:50 PM
rich7777's Avatar
Ha,ha.. you telling me... He's a human version of a turbo database to lol.
Old Apr 28, 2012 | 02:07 PM
agreed lol.
Old Apr 28, 2012 | 04:59 PM
Hidenplanvew's Avatar
OEM headgaskets are good for alot of power
BlakelyH19
Feb 15, 2007 12:58 PM
VTcivicHB
Jan 3, 2006 12:25 PM
Freemantle
Apr 5, 2004 12:54 PM
RuthlessEF-9
Dec 3, 2002 08:51 PM
Snafu-Si
Feb 18, 2002 12:50 AM
