Vacuum line on hondata map sensor
Old Apr 29, 2012 | 06:16 PM
protopro88's Avatar
Default Vacuum line on hondata map sensor
Im using a hondata map sensor on my boosted gsr setup. Im curious to see how people are getting the vacuum line to stay on when your pushing 20+ psi. Any help is appreciated. Thank you
Old Apr 29, 2012 | 06:46 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: Vacuum line on hondata map sensor
ruff up the map nipple with a little sand papper
then use a tiny smear of silicone on the nipple
slide hose on
cable tie it just like a hose clamp
let it cure
should be all good
Old Apr 29, 2012 | 06:54 PM
protopro88's Avatar
Sounds good! Ill have to try that. Any other good ideas
Old Apr 29, 2012 | 08:17 PM
98integralsB18's Avatar
zip tie always works
Old Apr 30, 2012 | 05:13 AM
Turbo-LS's Avatar
Correct me if I'm wrong but the map sensor is same as omni and there stock size and are to be mounted to the throttlebody right? why would you be putting a vucuum line on it? Unless its a da or ef. You can get a newer TB and mount it on there.
Old Apr 30, 2012 | 01:28 PM
protopro88's Avatar
Im also wondering that. Am i able to just put the map sensor in its original location (throttle body)?
Old Apr 30, 2012 | 06:39 PM
If its the one that turbo LS was explaining then yes.
Charlie Moua
Apr 13, 2012 08:24 PM
didder
Dec 16, 2008 11:13 AM
Topdawgg
Jun 25, 2007 10:02 AM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
