Where can I find this manifold?!?!
I have a greddy TD04 turbo for my b16a, and I looked everywhere for a TD04 manifold for it and can't find one. Anyone know where I can find a b16 TD04 manifold?
Moderator
Re: Where can I find this manifold?!?!
You don't. The GReddy TD04 15G turbo which uses a T25 inlet.. In which case you have to find a T25 manifold from GReddy to fit.. That comes from the manifold that comes in a GReddy 18G kit, which is the only GReddy turbo that will be anything even remotely close to a TD04 GReddy 15G
Either way, the TD04 turbochargers are WAY too small for any effective range on a B16. Yes, I know you don't want to make a "lot of power".. that won't be a problem....With a universal application, or the proper 18G
Use any T25 manifold for a B series, then put a block off plate over the external wastegate hole....but this turbo is going to require a custom fabbed downpipe flange.....and it is soooo tiny its gonna be poopy poopy poopy on a B16, not even worth it really.
Friend had it on his b16 stock, made 14.2 in a quarter with bad reaction time on 6psi.
A T3 Super-60 turbo will provide more power than that greddy, you won't be buying yourself an awkwardly flanged manifold without room to grow in the future, and it'll have a more broad powerband.
Wanting to base your turbo kit around one part of it that you have or can get for really cheap would be like buying a stained glass window and then deciding to build your entire home around it.
it was a bone stock d16z6 in a ek coupe full interior on a basemap turbo chip..and im not looking.to go that fast just want something a little faster than stock not looking to impress anybody so i can care less if a type r is faster or not
he has a b16 now but when the turbo was on he had a d16z6 in the coupe and ran 14.2 with street tirea with a 2.34 reaction time..so im sure ill be putting out more power and get into the 13s which im more than happt with
That is a horrible time for a boosted B16 or D16. A Super 60, 50 or 57 trim or the TDO5 18G turbo will be much better sized for a stock B16 and will be much funner to drive. The TDO4 will be maxed out on the B16, even a poor match for a D16.
+1 for the super60.
bone stock gsr with a t3 super60 @ 10psi. 290whp
more info: http://www.evans-tuning.com/dynos/20...hp215tq-10psi/
Im not looking to make that much power, what dont you people understand. I'm trying to only make 230whp. I don't want to make a **** ton of power. I want low 14s high 13s, no way am I trying to make 12s or 11s. If I wanted to do that then I would upgrade my turbo, until then I'm going to enjoy my car for what it is.
BMC racing should have an adapter plate... i got one from them when i used a wrx td04 turbo on my single cam with an hf manifold. that **** like spooled at idle. haha
Its not like the t3/super60 is a big turbo or anything, look at the powerband I posted above, it gets full boost at 3500rpms but unlike the pea sized greddy it will actually hold power until redline and not blow a whole bunch of hot air.
But if you don't care go get any t25 manifold, make it a pain to get a properly sized turbo later, and go have fun.
liam
Moderator
+1 for the super60.
Already have the downpipe, got it for free! I'm not dumb if it would cost me more money than it would be worth then I wouldnt do it, but I'm gettin good deals where I can thats why I doing this for fun and not HP.
