Boost controller how do you control your W/G?
Old May 9, 2012 | 10:25 AM
Steeve_Civic's Avatar
Default Boost controller how do you control your W/G?
I would like to know how do you control your external W/G Tial or PTE with a profec B or AVC-R.
Moreover do I need to cap unuse ports?
Example, if you control your external W/G by the bottom of the W/G do you cap the other port on the bottom and on the top?
Thks
Old May 9, 2012 | 01:41 PM
mechanix619's Avatar
Default Re: Boost controller how do you control your W/G?
It's not the best diagram but it gets the idea across. The bottom port on the WG connects to the turbo housing and boost controller, the top port on the WG connects to the other end of the boost controller.
http://www.tialmedia.com/documents/w..._wginstall.pdf
Old May 9, 2012 | 03:12 PM
Muckman's Avatar
Moderator in Chief
You dont cap any of the open ports.
Old May 9, 2012 | 04:39 PM
TheShodan's Avatar
Moderator
Correct. Use it in conjunction with the ProfecB instructions. Do not "cap off" any open ports.
http://www.greddy.com/upload/file/PRofec_Bspec2.pdf
Old May 10, 2012 | 10:36 PM
Thank you guys for your help
I have a problem because profec B turn Off I cannot control my boost...
Old May 11, 2012 | 12:57 PM
dpetro1's Avatar
the in-cabin unit turns off or the solenoid? either way sounds like a wiring problem. can you take a picture or describe exactly how everything is connected.
Old May 11, 2012 | 01:04 PM
TheShodan's Avatar
Moderator
if the unit is turned off in the cabin, it will automatically go to wastegate spring boost setting. without some other controller, you'll stay at the wastegate's spring boost pressure setting.
Old May 11, 2012 | 01:07 PM
dpetro1's Avatar
and it can be deceiving because the unit can be OFF (no boost control) but the display itself still lights up to display boost pressure.
Old May 11, 2012 | 01:09 PM
TheShodan's Avatar
Moderator
Absolutely. I get a lot of questions like that.. and it turns out that the unit is turned on.
Old May 12, 2012 | 11:21 PM
I've found the problem.
When you control the W/G by the bottom, you need to cap off the other Bottom port otherwise there is a leak.
Don't need to cap off the top.
Thks
Old May 13, 2012 | 06:23 AM
TheShodan's Avatar
Moderator
Umm. you use both the top AND bottom ports of the wastegate. One goes into COM, the other NC.
Old May 13, 2012 | 12:00 PM
no just 1 port on the bottom and port COM.
Port NO to the intake
Old May 13, 2012 | 02:52 PM
TheShodan's Avatar
Moderator
Whatever floats the boat. I've used 3 since 1999.. I'll leave you to it
Old May 14, 2012 | 07:37 AM
dpetro1's Avatar
this is incorrect for an external wg.
you want to run one lower/side port to the compressor housing (boost reference), the other 2 lower ports get plugged. top port to COM on boost solenoid. NC port to boost compressor housing (tee into side port line). NO is left open
i've attached the greddy instructions with the install diagram
File Type: pdf
Old May 14, 2012 | 10:51 AM
OK I'm going to try tomorrow like that.
Thank you
Turbo-charged
Dec 13, 2010 06:59 AM
nicktagz
Aug 23, 2006 08:12 AM
thruvines87
Dec 6, 2004 10:00 PM
smallttocs
Mar 2, 2003 12:30 AM
kidkutz
Mar 31, 2002 01:51 PM
