quick vacuum line question
Old May 3, 2012 | 02:38 PM
d15bfi's Avatar
Default quick vacuum line question
Hey guys been a while since I have been on here, got a couple quick questions, I just got a new gt3071 and it dies not have a spot on the compressor side for a vacuum fitting to thread in, looks like a spot is there to drill and tap, or is it ok to run the line from my boost controller to the intake manifold,I have a edleBrock performer x with a couple vacuum ports still free, I'm sure this has been covered somewhere just can't search to well on my phone, thanks the other side of the boost controller goes to my wastegate
Old May 3, 2012 | 02:47 PM
yungkhmer's Avatar
Default Re: quick vacuum line question
here ya go.
http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
Old May 3, 2012 | 02:52 PM
d15bfi's Avatar
You know I thought of doing something like that,I have a backdoor intercooler was thinking of drilling and tapping the pipe that comes off the back which is aluminum
Old May 3, 2012 | 02:53 PM
d15bfi's Avatar
In theory you want the shortest line and closest to the compressor, correct?
Old May 3, 2012 | 06:03 PM
met's Avatar
met
You can run it off the intake manifold, then when its hot out you get the same amount of boost.
Old May 4, 2012 | 05:43 PM
yungkhmer's Avatar
shortest line possible. just get that fitting and hook it up to the wastegate.
Old May 4, 2012 | 06:38 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
but isnt the boost pressure different from the compressor when you compare it to the IM manifold?
Old May 5, 2012 | 03:42 AM
yungkhmer's Avatar
Oh **** the boost controller part totally slipped my mind. but if I remember right top port of wastegate goes to EBC, bottom port of wastegate goes to turbo. I'm pretty sure boost pressure is a little different but I don't think its that big of a deal to make difference?
CleanLikeJdm
Jul 3, 2006 07:32 PM
FyReo3
Aug 6, 2005 04:35 PM
Evil DOHC
Dec 29, 2002 04:48 PM
kickz
Aug 8, 2002 04:35 AM
Mr. Vapor
Oct 3, 2001 05:54 AM
