ne experience with cxracing fpr
Old May 11, 2012 | 08:30 AM
lsvtec_hatchback's Avatar
Default ne experience with cxracing fpr
im doing my first turbo build and im trying to find a good fuel pressure regulator set up. i found the cxracing web site they have a comlete kit all hoses, regulator fittings, and liquid filled gauge for 119. just wondering if these will help or hurt me im shooting for 300 hp if this affects the thoughts on using it. my friend had issues out of his aem fpr that bolted on the fuel, rail leaning out while tuning. he went with the aeromotiveand said it solved his issue. thanks for the help
Old May 11, 2012 | 08:39 AM
kyden's Avatar
Default Re: ne experience with cxracing fpr
use an oem regulator. simple and effective.
Old May 11, 2012 | 08:41 AM
really ok i didnt no for tuning purposes if a adjustable regulator would b needed thanks
Old May 11, 2012 | 08:47 AM
cleansi's Avatar
i would stay off of ebay and cx raxing products completly.
the only thing i would personally might MIGHT ...use is there piping not even there couplings
Old May 11, 2012 | 09:02 AM
99siky's Avatar
I have used them before for parts but they were brand name parts. They are a decent distributor. They haven't sold me any knockoffs yet. But like cleansi stated, stay off ebay products. I bought all of my critical turbo pieces from a reputable shop in my city. No issues once you do that.
Also talk to your tuner about the FPR. He might say get one he might say keep it factory. Depends on what he wants.
Old May 11, 2012 | 11:30 AM
TheShodan's Avatar
Moderator
If the goals are reasonable on the stock engine with no plans to go with big power, stay with the stock unit, even with upgraded injectors for now.
Old May 11, 2012 | 12:26 PM
im using a d16z6 probably gonna go with the comp 59300 cam probably skunk intake, larger throttle body, bore it .5 mm over stock, 9.0:1 cr cp pistons, h beam rods, and get it tuned. im shootin for 300whp or as close as i can and it still b a reliable weekend car
Old May 11, 2012 | 12:42 PM
Gunmetal_B20_Hatch's Avatar
thats easily managed on a stock regulator w/ 550cc injectors,
Old May 11, 2012 | 01:05 PM
TheShodan's Avatar
Moderator
Meaning that no FPR is necessary
Old May 11, 2012 | 01:31 PM
Turbo-LS's Avatar
Agreed with Shodan, I personally wanted adjustability and went with B&M mod kit and im running a 50 base pressure and making little over 400whp on that which i believe is about the limit. Ill be upgrading my regulator here soon
Old May 11, 2012 | 05:31 PM
yungkhmer's Avatar
damn everyone is starting to want to use that cxracing ebay crap now. wtf lol
Old May 11, 2012 | 10:21 PM
i was wondering about the cx racing b/c there was someone on c-list that had a brnd new kit i had never heard of them wasnt sure if it was a cheap ebay brand or a reputable company. im just trying to cover all my bases so theres no set backs at the tuner. thanks for all the input everyone
Old May 11, 2012 | 10:30 PM
EsotericImage's Avatar
Retired Moderator
this
Old May 11, 2012 | 10:42 PM
hussain-vtec's Avatar
Agree with Kyden.
Example with OEM regulator Id1000cc,Aem Fuel raid got it for $50.
B20 Stock sleeve 6756 cast, 491Whp @18psi On Pump Gas
Hope that help.
Good luck
Old May 11, 2012 | 11:39 PM
rich7777's Avatar
Have you had any issues with that B&M kit? I.e. the fuel pressure swinging all over the place.
Old May 12, 2012 | 01:43 AM
yungkhmer's Avatar
I never had a problem with my B&M fpr. Had it on two different setups, one with 450's & the other setup with precision 1000's. If i remember right base pressure for both setup was around 50 also with steady flow.
Old May 12, 2012 | 04:14 AM
Turbo-LS's Avatar
I've never logged fuel pressure on a Dyno before but I've never had a fueling issue with the car with this setup for years. I'll only upgrade when I decide to run more boost and get a walbro 400 along with that
Old May 14, 2012 | 04:00 PM
MalcolmV8's Avatar
Seems CX Racing has a zero return policy so might watch out for that. I ordered a few parts from them including a turbo when I started my project thinking I was gonna use those parts. After looking over the quality and inquiring to return stuff they flat out refused to even hear of it. So just be aware anything you buy from them is yours.
As for the fuel regulator. I'm not running super high HP but on my setup I noticed when I put the 255 lph fuel pump in my base fuel pressure jumped higher than stock. I would assume because the stock regulator couldn't return the excess fuel to the tank quick enough? Not really 100% sure. However when I tuned the car I just tuned with that new base fuel pressure and it's good to go. Runs like a champ.
Old May 15, 2012 | 05:26 AM
ok cool thanks for all the help. i just didnt want to have to make multiple trips to the tuner can get expensive. ill go with the stock regulator. the B&M yall are talking about is it the one u cut your stock regulator in half. would that b worth getting in case for what ever reason they needed to adjust it or stay stock. i have the walbro 255lph in their already
got-vtec?
Oct 16, 2011 10:08 AM
1slowcrx
Sep 22, 2010 12:10 PM
bradyj001
Apr 11, 2009 06:21 PM
berts95ej
Jul 28, 2006 04:36 PM
qcktegls
Nov 16, 2004 07:42 PM
