Longshot basemap question
Old May 22, 2012 | 06:24 PM
porkythegrunt's Avatar
Default Longshot basemap question
Hey guys, this may be a long shot but its worth a try.
I was wondering if anyone here would happen to have a basemap/tune that is similar to my setup (It doesnt want to idle, and its not mechanical).
Pump gas (aeromotive 340 + inline bosch 044)
81.5mm B16 + ported GSR head
~11cr
edelbrock victor x manifold
ID1600s (im planning to go e85, but i want it to idle on pump for now)
Blox stage 2 cams
all this on Neptune RTP
thanks.
Old May 22, 2012 | 06:35 PM
Default Re: Longshot basemap question
*stock map sensor atm
Old May 22, 2012 | 07:38 PM
EsotericImage's Avatar
Retired Moderator
Why not just get ur tuner to do a street tune if u cant get it on the rollers
Old May 22, 2012 | 08:31 PM
yungkhmer's Avatar
nobodys gonna have a basemap/tune for you.
Old May 22, 2012 | 11:25 PM
Na-Spirit's Avatar
Contact Phearable.net. Maybe they can send you a chipped ecu with a basemap installed... Unless you can swap out chips using neptune? Give them a call.
Old May 23, 2012 | 12:55 AM
bc i dont trust any of the tuners here, and i would like it to idle by itself so i can make sure nothing leaks/etc etc before I do send it to a tuner.
Old May 23, 2012 | 03:18 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
If you don't have a tune and you have a stock map you need to remove this 1600 injectors and put your stock injectors back in followed by your stock map sensor. You can run your stock fuel setup all day just as long you don't go into pressure aka boost, shot Im did/doing it with no issues.
Old May 23, 2012 | 04:51 AM
Retired Moderator
even if you get some magical chip sent to you, theres a big probability that it wont be the fix. It will be a general map and not designed for your set up.
even if someone has the same set up as you, it wont be identical. you should look into other tuners that are reputable.
https://honda-tech.com/forums/forced-induction-16/%2Anew-tuner-directory%2A-2349805/
EDIT: I say this cuz you have spent alot of sweat and money on your build.. tuning is not the area to be cheap or foolish. this is the most important part of the build. personally, i wouldnt even drive it until it was tuned. too rich or too lean and you can be posting a much different thread on here.
Old May 23, 2012 | 04:57 AM
TheShodan's Avatar
Moderator
Pretty much.. then disconnect an I/C pipe so you don't go into positive pressure by accident. depending upon what part of MI you're in, you have few choices of tuners.
Old May 23, 2012 | 07:16 AM
dpetro1's Avatar
when you buy neptune don't you get a software license as well so you can download the program and make a basemap yourself? what map is it currently on? where did you get the current map?
Old May 23, 2012 | 07:36 AM
HRTuning's Avatar
If he has the RTP setup he can make changes. Start fresh if you don't know what's currently on it, calibrate your injector setup in the software, and adjust the overall trim as needed to get it idling.
Old May 23, 2012 | 08:18 PM
CO_RaceFab's Avatar
Icon3 Re: Longshot basemap question
I honestly can't believe you of all people suggested this... That can cause a turbo to over spin just driving normally.
Old May 23, 2012 | 09:10 PM
dcmatt's Avatar
I'm pretty sure he's stated that before in another thread and ive heard of a few ppl doing it without issue. Of course this was going very easy just to get to the tuner. Do you think it would be an issue if you stayed very low in the rpm range and only partial throttle. Asking outta curiosity.
Old May 24, 2012 | 07:47 PM
CO_RaceFab's Avatar
The tps goes from 0-100% you control this so just take it easy and you will be fine.
B18B_EJ1
Dec 28, 2012 09:13 AM
wolve
Engine Management and Tuning
Nov 20, 2008 09:05 AM
IntegracinGSR
Jan 11, 2004 01:27 PM
420aNT
Apr 8, 2003 08:11 PM
teg92
Dec 24, 2002 03:10 AM
