Motor mounts
Ok guys....Maybe this should be in suspention? But it is directly related to FI as I am wondering about motor mounts because I will be making 350-400whp.
I have always just used B swap mounts in the past as every car I have built so far has been a B swap.
This time I am boosting the stock D16y8, so swap mounts not needed.
Right now the car has tired stock mounts, and I know this will give me problems at 350+ whp. I am also running a solid disk six puck clutch.
I am considering 2 options for energy suspention poly inserts.
These:
http://www.ebay.com/itm/Honda-Civic-...f35405&vxp=mtr
Or these:
http://www.ebay.com/itm/Energy-Suspe...4847be&vxp=mtr
Opinions or suggestions?
These:
Or these:
Inserts are cheap, simple and they work period. You can also use Hasport or Innovative motor mounts. B and D use the same mounts so just get some for a 96-00 Civic. You said a D16Y8 so I assume its in a EK/EJ.
Just wondering on the style of inserts.....
The first one is a complete new insert, so I would have to push the old insert completely out and push the new one in, seems like the best choice, but is this gonna be a bitch to do?
second one is just the split inserts that you shove into each side of the stock insert, seems like these will be easier, but are they as good as the full insert?
Both inserts you linked are two pieces per mount. In the first link, they are just placed close together to make them look like a single piece. Look at the second picture in the listing, they are staggered so you can tell it's actually 2 pieces.
I have these inserts in my car (D16Y8), you can definitely feel a vibration increase. But wheel hop is down significantly, and shifts are more solid. I'd recommend them if you don't have the money for full replacement mounts. And the vibration isn't so bad that it bothers me, even though it's my daily driver.
I started with inserts but took a crap on me, i now have hardrace monts and they work well. But limited, i might just swap them for hasports or innovative.
i bought the solid mounts and i cant stand the vibrations, i just ordered all 5 from energy suspension and they just came in today actually, im gonna go with the street insert and i will report back. i prolly wont get them in until next weekend i have a bunch of other stuff to fix tomorrow.
How about these guys...?
HARDRACE motor mounts (Hard Rubber)
http://www.buyhardrace.com/product/h...ivic-ek_4.html
When we discussed this, it was a personal preference. I used these because of the fact that I don't drag race, and don't want vibrations in my engine bay, as well as the fact that the Mugen Hardened rubber has gotten more expensive and unavailable for mounts.. You know me by now, I rarely get the H-T bandwagon list of parts because of particular needs, ya know?
Thanks for the replies gents!
I think I will just do all 5 mounts with energy sus. poly inserts.
I know with my solid 6 puck I'm gonna get some chatter, and I think stock mounts will be a horrible idea with that clutch.
You will transfer ALL that energy into the cabin, and with that 6 puck, prepare to go to the dentist from your teeth rattling...
That will be interesting, indeed for you.
Mac, I have the hardrace mounts.. i still have a little rocking going on..
Im thinking of changing the driver mount only.. but the street or track hardness is what im wondering about.
so your saying with my clutch and the ener. sus. poly inxserts its going to be horrible?
What is a better alternative then? The other insert style?
I know with the stock mounts I have now ( tired with 120k miles on them) I am going to have wheel hop and major movement of the motor/tranny, so I dont want that.
This is going to be a street car mostly, so I def. want a level of comfort, but dont want crazy wheel hop and the motor bouncing off the motor bay walls....what is my best solution here?
Wait mac............
@boosted_D: Yeah, unfortunately, with the combination of that clutch and setup, you're going to hate life with it, but the other alternative would be either the hardrace, OR ,use a replacement OEM mount (with less mileage) on the driver's side and keep the poly on the rest. Its just so difficult to get the perfect combination for dual use when the whole intent of poly-mounts is to have more accurate feedback from the car and for it to not experience the stock feel of the car.
Have you looked into the HASport street mounts themselves, or are they a bit out of the budget?
hrrrmmmm.....sucky choices here......What if I just get new OE replacement mounts for both the uppers, then put poly inserts in the front lowers and the rear?
This will cost about $140, yeah, the hasports are out of budget unfortunatly.
I dont want super harshness, but I also dont want the feel of blown out mounts...
next weekend i will be doing all my inserts on the street ones not the race, i will post back with results compared to my solid ones, mine are tite racing mounts, made by a local guy here in ontario. but i am also still on an exedy stage 1 clutch so i wont be able to help u with that, i am going to try a 6 puck rigid once mine goes though, ive had a few guys swear by them so ill give it a shot.
I bought all 5 ES mount inserts but only installed the 2 upper mounts, just in case the vibration was too much for my daily. The car feels 10x better, shifts are more solid, faster and easier. But I still get some wheel hop.
I'm debating whether or not to install the other 3 after what Mac said. I already get a little extra vibration, only really noticeable when the car is idling at it's lowest RPM. I get the feeling the other 3 mounts are the ones that really make the difference in wheel hop, but also the biggest culprits for unwanted vibration.
Just install them. The vibration is not bad at all. I had all five in my car and vibration was minimal at best. I switched to inserts on the engine and trans mount and has port race rear torque mount, now that caused vibration. Lol
D16SohcVtec
Aug 12, 2008 08:03 AM
