Smoking problem
Old May 22, 2012 | 10:27 AM
derka_si's Avatar
Default Smoking problem
Hey everyone,
I never posted here before because I usually search and always find my answer but now i'm stuck and i cannot figure it out. I have a 99 civic si with a sleeve fully built ls-v. It has around 1k miles and it just recently started smoking a lot. I did a compression test and it was between 185-195psi, ( CP 9-7-1 pistons) and the leak down test was all around 10% which I think is good for having bigger ring gaps. The problem I'm having is the car is smoking at idle, and driving. It a lot of smoke and i'm stuck. I had the turbo checked and it the turbo is fine. There is oil coming out of the number 3 and 4 exhaust port and I also notice that between the t4 flange and the turbo it has oil reside right around there. It is smoking really bad and cannot figure out. Any ideas?
Old May 22, 2012 | 12:06 PM
derka_si's Avatar
Default Re: Smoking problem
anyone?
Old May 22, 2012 | 12:13 PM
zerovandez's Avatar
Seems like bad valve seals would be the culprit being that you have oil leaks out of exhaust ports.
Old May 22, 2012 | 12:40 PM
Skalabala's Avatar
Could it be head gasket leaking oil? Does sound like bad valve stem seals, could even have worn guides helping the oil going into the combustion chamber.
Old May 22, 2012 | 01:18 PM
B18C1CYA's Avatar
Valve seals , Just had the same problem, where are you located?
Old May 22, 2012 | 01:28 PM
derka_si's Avatar
yeah i was thinking it was the valve seal. some people were saying ring but i didn't think so. I didn't think valve seals would smoke at idle and while driving though. I am located in Florida. I also didn't think valve seals smoke really bad. when i rev it, the smoke could fill my entire garage lol
Old May 23, 2012 | 01:37 AM
Skalabala's Avatar
You should have the guides checked also to be sure you do not get the same problem over a few months.
Old May 23, 2012 | 03:24 AM
jubbeng's Avatar
i hope this is not ur case but i had the same thing happen to me it turned out to be no 2 piston skirt broke off completely taking the oil rings with it.
i say tear her down and check everything buddy.
good luck
Old May 23, 2012 | 10:54 AM
Skalabala's Avatar
Oh goodness! Yes this is not impossible! ^^
Old May 23, 2012 | 01:14 PM
derka_si's Avatar
If that happens though wouldn't that scar up the cylinder walls and the compression test would be low? I first thought my head gasket was bad so i replaced the head gasket and i looked in the cylinder walls. Looked good to me when i had the head off. I'm having my valve seals checked out this weekend and go from there. Thanks for the response!
Old May 23, 2012 | 01:26 PM
jubbeng's Avatar
my compression was perfect before i took the motor apart even my leakdown test was good but my 2 compression rings were still on so thats why the readings show up normal, i took the motor apart because of the oil coming out the exhaust.
i know u dont wanna tear it down but look at the bright side u can inspect the motor and see if bearings etc. are good.
Old May 24, 2012 | 01:19 AM
Skalabala's Avatar
Oil rings could also fail and cause oil pumping.
But it is most likely the stem seals.
Old May 24, 2012 | 12:55 PM
derka_si's Avatar
so i figured out the issue. I have a borg warner s366 t4 twin scroll. All i did was put an oil restrictor in it because i saw oil in my intercooler piping and the smoke went away. Everyone told me that i am not suppose to run a restrictor on that turbo? Have anyone else have this issue?
kyleboosted_94
Jan 5, 2018 07:08 PM
TravisBiggie
May 27, 2012 04:54 PM
riS.I.R
11
Apr 2, 2009 06:15 PM
8YourV8
Dec 28, 2006 01:05 PM
redline201
Sep 3, 2003 10:24 PM
