Help finding a FMIC
Old Apr 20, 2012 | 04:21 AM
CWBETB's Avatar
Default Help finding a FMIC
Got to semi test fit a friends front mount. Its a little to big. The specs on his is 30 inch long, 3 inch depth "end caps", 6 1/2 inch height, inlet/outlet 2 1/2
I need something that is more like 30 inch long, depth needs to be 2-2 1/2, height needs to be more around 6 inches and the inlet outlets can be around 2-2 1/2
Anyone recommend a affordable FMIC in these specs? Is Johny race car FMIC still around?
Old Apr 20, 2012 | 05:32 AM
CWBETB's Avatar
Default Re: Help finding a FMIC
http://store.max-redline.com/servlet...5%22%2C/Detail
Ok one above might work well
Old Apr 20, 2012 | 06:51 AM
boosted_D's Avatar
also talk to Go Autoworks, they are a board sponser and will hook you up with exactly what you need...
Old Apr 20, 2012 | 07:20 AM
CWBETB's Avatar
Thanks!
This might work out well
http://www.cxracing.com/mm5/merchant...Category_Code=
- Bar & Plate Aluminum Intercooler
- Core Size: 21"x5.5"x2.5"
- Overall Size: 28"x5.5"x2.5"
- 2" Inlet & Outlet
- 2.5" Thick Core
at this size I might be able to get away with no cutting, just removing the front grill, also the smaller inlet/outlet will help
Old Apr 20, 2012 | 07:26 AM
Hidenplanvew's Avatar
not a fan of ebay stuff, but I have used a Cx Racing intercooler on the drag car and it held up fine.. just needed it in a pinch and was in a buddies garage
Old Apr 20, 2012 | 07:41 AM
boosted_D's Avatar
If your going to go ebay.... cx racing and godspeed are your 2 best quality bets, I'm actually using a cx racing intercooler and charge pipes on my current build as well...
Old Apr 20, 2012 | 08:23 AM
CWBETB's Avatar
Thanks Im using this on a boosted ZC thats only about 200hp btw
slowslow
Apr 26, 2007 02:28 PM
jdm integ
Mar 6, 2006 06:41 PM
Junior_r
May 23, 2004 09:33 AM
