b20 vtec turbo help
Old Apr 27, 2012 | 12:43 PM
boosted20psi's Avatar
Icon2 b20 vtec turbo help
i have a 97 civic with b20b block and b18 typer head turboed pushing 20psi.It is tuned and fully built. Im having a problem with the car starting,it will start but it takes a while it turns over for a minute then finally cranks but you have to hold the accelerator on about 3000 rpm or higher for a while before it will idle on its own. Another thing is when im suposed to hit vtec my car spits and sputters losing its power.Its also not wanting to charge the battery. I have been thinking this problem is in my harness but not sure. Does anyone else have a clue to what it might be thanks.
Old Apr 27, 2012 | 03:16 PM
phaphon's Avatar
Default Re: b20 vtec turbo help
YOUR ALTERNATOR MIGHT BE BAD? MY BAD FOR THE CAPS MY PHONE IS RETARDED
Old Apr 30, 2012 | 07:21 AM
i have checked the alternator and its charging putting out 14.1 volts just not sending power to battery also grounds are all good
eschel
Jun 12, 2015 01:42 PM
ej2man
Jan 13, 2009 08:58 AM
crowder13
Oct 17, 2007 12:37 PM
aznsins88
Sep 13, 2004 09:13 PM
