Tune question regarding injectors
I have dsm 450 injectors with a resistor box. I had a turbocharged car with a tune. I took everything turbo out and now run a stock basemap but have my 450 injectors still. Would running these on my now stock base map flood my engine with fuel or will the ecu correct it?
The fuel map/table is what tells the ECU how long to hold an injector open depending on load and rpm. If the stock fuel map is calling for 3 ms of pulse width at 4500 rpm and 50 kpa, it's going to hold your injector open for 3ms - regardless if your injector flows 200cc/min or 2200cc/min.
The ECU has no idea what size injectors it's controlling, it's simply holding a circuit open for a predetermined amount of time.
A stock ECU can not compensate for different sized injectors. Your engine will run very rich if you can't 1) run the stock injectors or 2) modify the fuel map.
