Need Help with First Build
Old May 2, 2012 | 10:16 PM
Infamous war's Avatar
Default Need Help with First Build
Hey fellas, so i am having trouble getting my car to start running..Here is a little info about my setup.. Its a b16a2 fully built by slomotion here in Ohio. I recently put on a turbo kit. Ram horn, downpipe, dumptube,Wg, boost controller, fuel pump, etc. I also changed on my cams from all motor cams to gsr cams.
THE PROBLEM:
This is what its doing. Soon as you start it, it idles for like 2 seconds and shuts right back off. With even giving a little gas it still turns off.. I'm so lost!!!!!!
Could it be the timing?
If its the timing how to check with no marks being on crankpulley? We took some hangers and tried to find TDC by putting one in and watching it come up to the peak.
Is there another way to checK?
I want to get a timing light, but if the car wont stay started then how am i suppose to check.
Please Guys help me get this thing up and running.
Not looking to get any bashing, just some good advice to help me.
Old May 2, 2012 | 11:22 PM
b18b1turbo's Avatar
Default Re: Need Help with First Build
What engine management are you using?
Old May 3, 2012 | 04:21 AM
I have a s100 I'm right now. But have a s300. Just need to change it to have vtec and get a base map. Could this be where I'm running into issue? I don't have a base map on s100 for my turbo setup, but I figured I could atleast start it and hear it idle.
Thanks for your response. Keep the help coming
Old May 3, 2012 | 04:24 AM
MRGRIM's Avatar
R.I.P. Mark
get your ECU right with a base map on the s300 ...before somthing goes bang
be safe not silly
Old May 3, 2012 | 04:32 AM
Agreed. I need to get s300 setup. So is my problem coming from the ecu you not being for setup?
Old May 3, 2012 | 04:45 AM
boosted_D's Avatar
What injectors do you have in it?
If you have bigger injectors than what was in it before, and the hondata has not been re calibrated to compensate for the larger injectors, then that is why it wont idle.
Old May 3, 2012 | 04:58 AM
I have stock injectors still on the motor. Wasn't going to change until it started and everything was running.
Old May 3, 2012 | 06:17 AM
phaphon's Avatar
Did you adjust your valves when you change the cams ?
Old May 3, 2012 | 07:22 AM
No I didn't, everything I have read never said I would have to. I'm New to the whole building part so please tell me anything I need to do to make it run.
Old May 3, 2012 | 07:39 AM
phaphon's Avatar
You need to adjust your valves
Old May 3, 2012 | 08:06 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Have you checked your grounds?? I was having a issue with my swap starting and then immediately dying. Turned out it was the grounds on the t-stat!
Old May 3, 2012 | 08:21 AM
Thanks. Would you happen to know the specs for it? I'm hoping this is the problem.
Old May 3, 2012 | 08:26 AM
I will have to look into all the grounds again. The only ground I touched was from valve cover. Just so ready to get it done but want to make sure it's done right
Old May 3, 2012 | 08:39 AM
boosted_D's Avatar
when you do get it to start, do you have to crank it for very long to get it to start?
and does it run rough for the few seconds it stays running?
Old May 3, 2012 | 09:11 AM
Runs smooth and starts after 2-3 seconds of cranking.
Old May 3, 2012 | 12:42 PM
boosted_D's Avatar
This makes me think its not a timing issue....It still could be, and I would re check it still....
Normally if the timing is off far enough to stall the motor, its a lot of hard cranking to get it started, and once its running it runs like ****.
I would revert back to checking grounds, etc.
Was it running fine all motor on the motor it has now before you put the turbo kit on? Or did you put in the built motor and put the turbo set up on it all at the same time??
Old May 3, 2012 | 02:30 PM
It was running fine before we put turbo kit on. The motorbwa already built and had about 25k on motor. I am going to check grounds and valves like suggested. Thanks for all the help fellas.
Old May 3, 2012 | 03:26 PM
phaphon's Avatar
I'm not sure idont remember but i think i adjusted mines to .007 intake and .006 exhaust double check before you do it I might have it mixed up.
Old May 3, 2012 | 09:20 PM
artie89's Avatar
make sure you set your tps up rite
Old May 3, 2012 | 09:36 PM
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/valve-adjustment-b16a2-question-3049496/
Originally Posted by 00_EKHatch
.005 on the intake
.007 on the exhaust
Do not over tighten the lock nuts. And double check each adjustment you make before moving to the next set of valves, and take your time. This might help.
Old May 3, 2012 | 10:35 PM
phaphon's Avatar
That looks a little tight
Old May 4, 2012 | 09:28 AM
Thanks. I will try and see if of these suggestions work this weekend. Also I don't know if this would make a difference but I had stage 2 all motor cams before i put the Gsr cams in. Just tryin to give a little more insight to you guys to help me figure out issue.
Old May 4, 2012 | 09:32 AM
phaphon's Avatar
That makes a big difference . That the reason you need to do a valve adjustment
Old May 4, 2012 | 09:40 AM
Good stuff. I hope that's whats giving me the issue. I have a high compression motor and I know it's not good for DD running a lot of boost. But I would like to get 350whp. And I'm almost there. Need it to start, a wideband and tune. If anyone selling a wideband let me know. Thanks again for all the help.
Old May 6, 2012 | 06:02 AM
Bump
