oil and draining for a borg warner s360
Old May 10, 2012 | 12:22 PM
sh!ft's Avatar
Who the fack changed my title?!
Default oil and draining for a borg warner s360
so i have a borg warner s360 that i will be using and i was talking to a friend of mine and he mentioned(while i was picking up some screws for the drain fitting at lowes) about how some turbos use oil jets because if you feed it(the turbo) too much oil it will mess it up. and if you starve it, it will mess up. i already had a fitting that came on the turbo when i bought it and was wanting to know if it would work. i got a few pictures as well to give you a better picture
oil feed^
the inside of the oil feed. there is also another small oil port there as well. which i was assuming was the oil control orifice or something of that nature.
thats the fitting that came on the turbo. this turbo has never EVER been ran. just mocked up.
another question i had was if this is ok as in terms of an angle to run the turbo
as well as running the drain from here........
down to here........
ending up there
thanks for all who can answer my question(s)!
Old May 10, 2012 | 12:58 PM
rs250nut's Avatar
Default Re: oil and draining for a borg warner s360
You should run the turbo in a upright position like in the first position.
Old May 10, 2012 | 01:11 PM
Dc4LsTeG's Avatar
EK9
X2
Old May 10, 2012 | 01:59 PM
sh!ft's Avatar
ya i figured that would be suggested. but as far as the feed line goes, should i get an oil jet or just keep what was supplied with the turbo? sure wish the shodan was here
Old May 10, 2012 | 04:28 PM
figi fg2's Avatar
For the feed usually only ball bearing turbos require a restrictor, you could make a 5 min call to borg warner and they'll give you the required information. On the return you want to make the return point as straight down as possible, since it works off gravity, and run 10an line.
Old May 10, 2012 | 04:35 PM
sh!ft's Avatar
ok. any particular reason why a 10 and not a 12?
Old May 10, 2012 | 05:02 PM
TheShodan's Avatar
Moderator
You want to keep the drain flowing but not drain too much out at once. This why you want to stay with the -10AN.
As for the feed, that is the British Pipe thread style that comes with Borg-Warner box units like the S360 non-extended tips. You want to get the A80 Weldon 1/4NPT fitting found at Home Depot and not what was included with the turbo for any Honda.
Old May 10, 2012 | 05:24 PM
sh!ft's Avatar
ok. will look it up when i get the chance. i just realized i ran into a problem that could potentially make my build go one direction or another. gotta do some thinking and decide what i am going to do.
Old May 10, 2012 | 06:48 PM
civgt28's Avatar
-4an feed is what i was recommend to use, got a bullseye s362 which is a borg turbo
Old May 10, 2012 | 06:50 PM
TheShodan's Avatar
Moderator
Dependent on fuel pressure, not just -AN size
Also, OP, DO NOT USE A 90* Bend on that return line. that will cause an oil backup issue. Only use a 45* please.
Old May 10, 2012 | 07:06 PM
Khnemu's Avatar
Oil*
:O
Old May 11, 2012 | 04:32 PM
sh!ft's Avatar
just picked up 2 xrp 45's so hopefully that will put me in the right direction.
Chee_dog
Aug 30, 2007 11:10 AM
coseal
Jan 28, 2003 06:34 AM
