Bolts Loosening up?
Bolts Loosening up?
Today the wastegate bolts were totally loose, the downpipe bolts were loose, The turbo to manifold bolts are loose! ( I think only one) and it looks like it ripped apart the gasket on the side it became loose, and where the exhaust leak is.
Pretty much, what the hell do I do to keep these bolts in? I can use loctite on the wastegate, and the downpipe to turbo, but I don't want to use it on the bolts for the turbo to manifold, because I know I'll have to remove the turbo/downpipe to remove my oil pan for example (its impossible to install the DP when the turbo is mounted already.) Also, I think it says loctite is only good for 300 degree F, which I don't think is suitable for the wastegate, and downpipe to turbo. Thoughts?!
http://www.youtube.com/watch?v=J1kJHkQrrnM
just a lil 3rd gear pull. Currently on 7psi. I have a 10lb spring, but the tuner recommended not to run 10lbs without arp head studs, so I followed suit. I have arp head bolts that I am going to install this weekend. What should I do while the head is off? Can I do anything that will benefit me without ripping the block apart? I will be using an OEM head gasket.
Retired Moderator
Re: Bolts Loosening up?
I have the 38mm 2 bolt style.. I used the black coated allen bolts with lock washers. works fine for me..
As far as the manifold.. I also had issues with my 1st cast mani bolts backing out. You can either use studs or use large allen head bolts with lock washers. I didnt use the cheap hardware that came with it.
Bottom line is replace it all with quality bolts and lock washers.
_Endless_
06-09-2003 06:58 AM
