Strange problem with Turbo GSR
Old Apr 22, 2012 | 04:11 PM
accord2civic2prelude's Avatar
Default Strange problem with Turbo GSR
Compression numbers:
#1:235
#2:230
#3:190; 225 with half a cap full of oil
#4:230
Leak Down:
#1:0%
#2:3%
#3:40% Air coming from number 2 cylinder while performing
#4:9%
Smoke blowing from exhaust, white with blueish tint when accelerating and grayish when letting off. With the comp numbers going up with oil in cylinder, suggests rings right? I have oil in my radiator, suggests headgasket right? Could a blown headgasket be the cause of the low comp in #3 and reason why air is passing through #2?
Old Apr 22, 2012 | 04:51 PM
Whiterice-gsr's Avatar
Default Re: Strange problem with Turbo GSR
yuppers, pull the head man.
Old Apr 22, 2012 | 06:01 PM
Turbo-LS's Avatar
Bad HG ftl
Old Apr 24, 2012 | 07:44 AM
So headgasket is the culprit. Better than rings i guess. But we will see.
Old Apr 24, 2012 | 07:53 AM
boosted_D's Avatar
The HG for sure.......what are you going to use for replacement HG and Bolts?
To avoid this problem again, use either oem or fel-pro HG, with a light coat of copper spray, and ARP head studs Torqued properly.....
BTW: A fel-pro MLS is as good as oem honda, oem=$80.....fel-pro from most places=$70
fel-pro from www.rockauto.com = $30 And yes it is the exact same MLS one that others sell for $70, but other places are marking it up because they know of it's use as a true oem replacement for performance builds, rock auto just simply sells them as a replacement part thus not bending you over and charging $70 for a $30 part...
Old Apr 24, 2012 | 02:41 PM
Didn't know that. Going to check it out today. I was going to go with cometic and arp studs. I know cometics are good, but am i just paying for the name because i usually use oem gaskets.
Old Apr 24, 2012 | 02:44 PM
oem or GE, FTW
Old Apr 24, 2012 | 04:30 PM
nealnanoHX's Avatar
Pretty sure FelPro makes the Honda OEM head gasket. I have pushed FelPro head gaskets pretty hard and never had an issue with one.
Old Apr 24, 2012 | 04:34 PM
LightningTeg's Avatar
Community Builder
I'll agree Felpro is probably close to as good. Felpro stuff has always been good for me
Old Apr 24, 2012 | 05:39 PM
and felpro
Old Apr 24, 2012 | 06:28 PM
Check out the first pic. Cylinder 3 had it rough!
tech6923's Avatar
time to pull the head!
Old Apr 24, 2012 | 06:36 PM
Sorry for the bad pics.
Old Apr 26, 2012 | 08:41 AM
Bump. The head and valvetrain is good. With the piston being egged like that and the walls aren't scored bad, except for the very top of wall has like rough carbon build up, would just a hone be ok since going back to n/a for now?
Old Apr 26, 2012 | 11:47 AM
boosted_D's Avatar
Should be fine even for boost as long as the PTW clearance stays withing reason....let your machinist figure that out, but if the PTW is going to go above like .065 you will have slap, so better off to bore and run bigger pistons.
Old Apr 27, 2012 | 03:05 PM
if its just going back to n/a and dd i would just ball hone and change the rings while youre there. maybe stick some plastigauge in the rod bearidngs to confirm everythings in spec, plus u will have the chance to clean the coolant out of them which destroys them.
Hernst
Jun 11, 2015 10:01 AM
siblue_gzer
Mar 18, 2008 09:48 AM
Meatwad1355
Jan 9, 2007 04:14 PM
djtony5
Oct 30, 2005 03:35 PM
FastNFurious
May 20, 2003 04:29 PM
