help please boost problem
Old May 15, 2012 | 02:17 PM
kingzac876's Avatar
Default help please boost problem
okay well i have a full built b16 with a percision 6262 turbo one month old and everytime i hit boost my car only going to 5psi (8psi spring) then at 45-6k rpm it will cut off and go back to vacum 20
car has
3 bar gm map
880 injectors
walbro 255
tail waste gate that works tried diffrent wast gastes
greedy type rs bov
custom intercooler
custom manifold
68mm throtle body
skunk 2 intake mani
and
built block built head
please help out
stumped on this changed spark plugs changed out map waste gates and some other things
Old May 15, 2012 | 02:24 PM
ChingaDEboost's Avatar
Default Re: help please boost problem
sound like boost cut on the map what ECU are you running '
Old May 15, 2012 | 02:47 PM
kingzac876's Avatar
its on a p28 and i have tryed 3 diffrent tuners and its still doing
Old May 15, 2012 | 07:16 PM
civickiller's Avatar
double check timing
Old May 15, 2012 | 08:01 PM
kingzac876's Avatar
checked the timing all good-__-
Old May 15, 2012 | 09:47 PM
Nwboostedeg's Avatar
I was having a problem like this, But my car has a boost cut at 15psi & it was cutting at about 10psi. Ended up having a hole in the line going to the boost gauge and boost was actually higher then it was reading. So I replaced the line and turned down the boost. Now it runs fine.
Old May 15, 2012 | 09:57 PM
kingzac876's Avatar
on my car you can feel the hole car die i wish it was that but you can feel the hole car just cut out
Old May 15, 2012 | 11:46 PM
da_dude's Avatar
Is it tune?
Old May 16, 2012 | 08:16 AM
kingzac876's Avatar
street tuned it started doing that and we couldnt figure it out went to another tuner still did it went to king performance they made a bass map an still did it
Old May 16, 2012 | 08:39 AM
boosted_D's Avatar
1. Check for boost leaks.
2. Make sure TPS is calibrated and working correctly.
3. Switch back to oem MAP sensor, and have a tune that reflects this change.
Old May 16, 2012 | 09:00 PM
kingzac876's Avatar
no boost leaks
going to get it hooked up on the live feed to find out about the tps and i have changed maps but ill try a stock map tomorrow
thanks for the feed back
viper_boy403
Engine Management and Tuning
15
Jun 15, 2014 08:17 AM
bads2k
Jun 8, 2011 05:32 AM
HondaTeKnology
Aug 17, 2009 11:25 AM
junyekh22t
Jun 8, 2006 07:02 AM
ion_four
Aug 12, 2002 07:59 AM
