Fast Turbo Oil Line Kit Question
I just got a new oil feed kit from Fast Turbo.com. Love their oil kits. But a question came across my mind before this install. In the kit there is a block adapter fitting that is silver and screws onto the end of the t fitting. the hole in the silver fitting is smaller than the hole in the t fitting. I just wana make sure this is ok or do i just screw the actual t fitting into the block without the silver block adapter fitting. The block fitting looks like it will restrict oil flow. Idk
Re: Fast Turbo Oil Line Kit Question
ive been using this kit from Fast-Turbo on my car for years on a journal bearing turbonetics turbo, and i havent had a problem with sufficient oil feed to the turbo.
the silver adapter is a bspt->npt adapter. the block is bspt which is a slightly different thread pitch. block->adapter->tee. you may consider remote mounting the fee to reduce the weight off the block.
i messaged fast turbo but no reply...i cant imagine the adapter with the slightly smaller hole diameter being a big issue though right?
engine block->silver adapter->AN line->npt block(firewall)
almostboostedgsr
02-07-2007 01:35 PM
