boost limitation
Old Nov 10, 2008 | 06:34 AM
lunch_box_4_life's Avatar
Default boost limitation
i am getting ready to start a sohc vtec turbo build and i was wondering what the most boost i can run on factory sleeves with a block gaurd
on a d16y8 block
Old Nov 10, 2008 | 06:39 AM
sneakysneaky's Avatar
Default Re: boost limitation (lunch_box_4_life)
its not about preasuare but about how much air you are moving into the motor.
a t25 at 20 psi probably wont make enough power to destroy anything.
but a gt42r at 14 psi would probably leave you laughing your butt off
after a pull or 2 when tuning.
Old Nov 10, 2008 | 06:45 AM
redrim's Avatar
Default Re: boost limitation (sneakysneaky)
what?dont tell the kid that,get him a link to a tuning thread.
Old Nov 10, 2008 | 06:55 AM
ok well then i'm looking at a go-autoworks turner kit
with a bulls eye t3/t4e with a trim of 50 and a/r 55
what is the boost i'm should run and still be safe on slock sleeves with a block gaurd
Old Nov 10, 2008 | 07:04 AM
BlakeJ53's Avatar
Block gaurds are pointless
Old Nov 10, 2008 | 07:40 AM
neoc03's Avatar
Research! A block guard won't help you with stock pistons and rods still in the block.
Old Nov 10, 2008 | 09:01 AM
just saying psi doesnt make power air flow makes power.
its usualy a certian power level that poeple see motors coming apart at,
but not all motors handle the power the same. whoever tuned your 440hp
b18 should be able to tell you what hes seen a setup like yours handle.
Old Nov 10, 2008 | 09:15 AM
Default Re: (neoc03)
i never said anything about stock rods and pistons
i am going to run vitara pistons and fjt rods
with probably a bisimoto cam and a skunk2 im and tb
Old Nov 10, 2008 | 09:51 AM
Default Re: (lunch_box_4_life)
https://honda-tech.com/zerothread/1643764
read through these posts and you will understand what everyone is doing
with pistons and rods.
tonys91tegra
Jul 9, 2009 11:07 AM
Boostin_GSR
Apr 4, 2007 12:21 AM
tobe1424
Aug 16, 2005 10:11 AM
Big Bang
Aug 12, 2004 01:38 PM
CANTFAZZDISCHIT
Jul 9, 2004 07:18 PM
