Vavle Adjustment
Old Nov 4, 2008 | 05:51 PM
kte324's Avatar
Default Vavle Adjustment
My question is do you insert the feeler gauge between the cam and the rocker arm or the rocker arm and the top of the valve. I have done a search and got both ways. My head is a little noisy but I believe its the lma's but im going to check my clearances just for sure.
Old Nov 4, 2008 | 06:09 PM
HiProfile's Avatar
Default Re: Vavle Adjustment (kte324)
SOHC's are nearly impossible to measure between the rocker/cam, and pictures always show the valve/rocker spot. For B's, Helms shows it between the rocker/cam in the pictures. Specs are virtually the same, which still makes sense since you'd want the higher-rpm head with some extra clearance.
Old Nov 4, 2008 | 07:23 PM
jdm inc's Avatar
heres a link on how to for a b-series http://www.c-speedracing.com/h...t.php
Old Nov 5, 2008 | 03:14 AM
kte324's Avatar
Its a b16 head that I am trying to adjust. That link above shows it being done between the valve/arm but others show between cam/arm. Im so confused.
Old Nov 5, 2008 | 11:48 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (kte324)
all b's i go between lobe and rocker. d's between rocker and valve stem tip.
Old Nov 13, 2008 | 01:52 PM
jdm inc's Avatar
RacerJ
Engine Machining & Assembly
Jun 15, 2018 11:17 PM
Faraz123
Aug 5, 2013 09:10 PM
95gsr
Apr 8, 2003 07:20 AM
khoalie
Mar 25, 2003 03:25 PM
White Lightnin
Mar 10, 2003 09:30 AM
