Built motor H23A1 question about misc part.
Old Nov 2, 2008 | 05:08 AM
sobeman81's Avatar
Default Built motor H23A1 question about misc part.
So, i got my H23 completely built. The shop that did it for me sent me one of their balance shaft eliminator kits along with the motor. There is ONE piece i got that i have No clue where it goes or what it does. In all honesty, it looks like an oil restrictor, but i could be dead wrong about that. My friend did mention it could be OEM because they use something similar to what i have for NON-V-TEC motors. For V-TEC motors, it gets ripped out in order to allow oil flow to actuate V-TEC.
On to the pix.
This is where it seems to fit on the deck of the block.
Please let me know about this. I wanna try and finish putting most of it back together today.
Also, would it be a good idea to use some gasket maker on the rear main cover when putting it back on the block? I already got a new seal installed on it. But, should i worry about it leaking from where the cover contacts the block or no? TIA for all the help guys.
Old Nov 2, 2008 | 05:15 AM
sobeman81's Avatar
I did forget to mention that when u see it in the pix, it looks like it is sticking up It's not. i just set it on there, it needs to be pressed in to seat it.
Old Nov 2, 2008 | 07:22 AM
98vtec's Avatar
moderator emeritus
Default Re: (sobeman81)
thats where it goes
Old Nov 2, 2008 | 08:07 AM
sobeman81's Avatar
Default Re: (98vtec)
ok, but do i use it for a boosted motor? I'm thinking the more oil flow the better, no?
Old Nov 2, 2008 | 12:36 PM
LShatchie's Avatar
you want to keep that in there
Old Nov 2, 2008 | 01:17 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sobeman81 &raquo;</TD></TR><TR><TD CLASS="quote">ok, but do i use it for a boosted motor? I'm thinking the more oil flow the better, no?</TD></TR></TABLE>
its the vtec feed. You dont need it.
Old Nov 2, 2008 | 06:54 PM
sobeman81's Avatar
awesome. thanks for the info guys. much appreciated.
Old Nov 2, 2008 | 07:32 PM
98vtec's Avatar
moderator emeritus
sorry, i just read my post again and it was a little confusing. Just to clarify, you should keep that plugged into the block.
Greddy95GSR
Nov 10, 2010 12:07 PM
WavyIntegra
Feb 7, 2010 04:51 PM
yarara0825
Jan 30, 2008 03:23 PM
preludepower420
Mar 27, 2007 10:50 AM
squidward
Jul 2, 2002 09:03 AM
