obd2 dead end
Old Nov 1, 2008 | 09:12 AM
inthad's Avatar
Default obd2 dead end
i'm installing dsm injectors.
right now I think i found the obd2 dead end clip. But there are more wires then obd1 deadend clips. Its yellow and black strips.
Please help out.
Its going on 99 civic si
b16
Old Nov 1, 2008 | 09:34 AM
eg9racer's Avatar
Default Re: obd2 dead end (inthad)
Use an multimeter and test for continuity between the injectors and the dead end plug. And test one of the wires for +12v.
Old Nov 1, 2008 | 12:16 PM
HiProfile's Avatar
Default Re: obd2 dead end (eg9racer)
The injectors will run 4 signal wires (each different color) to the ecu, and the other four are usually the same and tie right into ground. If you check the clip's connections to ground, you'll find the right wires. The resistor box can be put ANYWHERE on that ground wire, it doesn't matter. Just don't do it on the signal wires - all 4 injectors will fire each time you inject fuel. 4 times the fuel amount is bad...
Old Nov 1, 2008 | 03:26 PM
inthad's Avatar
Default Re: obd2 dead end (HiProfile)
so is that the rigth dead end?
Old Nov 2, 2008 | 09:02 AM
HiProfile's Avatar
It might be, but you need to check it yourself. Take a cheap multimeter ($10 at radioshack, checks resistance & voltage), touch one lead/point to the engine block, the other onto the deadend (follow a wire to the injectors). If you get zero volts and ~0.4-2 ohms, that should be ground. If it says +12 volts, that is NOT the right deadend connector.
Old Nov 2, 2008 | 09:43 AM
eg9racer's Avatar
Heres a couple links that might help you out.
https://honda-tech.com/zerothread?id=2385715
https://honda-tech.com/zerothread?id=2393875
Resistor box should recieve +12v not ground.
Old Nov 2, 2008 | 04:17 PM
inthad's Avatar
thanks guys
clicky79
Oct 17, 2018 08:18 AM
inthad
Nov 10, 2007 05:34 AM
turbo_ef9
Jan 24, 2005 09:47 AM
booscivic
Feb 15, 2004 05:26 PM
chuckd05
Dec 27, 2001 10:00 PM
