Type R intake or Venom
Old Nov 6, 2008 | 12:20 AM
slowsiEG's Avatar
Default Type R intake or Venom
I am boosting a GSR motor with ITR intake and b16 exhaust cams. running a garrett t3/60-1 turbo with .63 AR. Bottom end sleeved by Benson stock bore and stroke with pauter rods looking to make somewhere between 450 - 500 HP. I have the choice between an ITR intake or a venom. Any recommendations for a DD with these choices on intakes?
Old Nov 6, 2008 | 01:38 AM
FULLYBUILT2.0's Avatar
Default Re: Type R intake or Venom (slowsiEG)
type r is nice but it too stock if your looking for all that power like you said....u should get the venom cause it will give you more power and hold boost better...
Old Nov 6, 2008 | 06:39 AM
Schister66's Avatar
Man U FTW
Neither...get an Edelbrock
Old Nov 6, 2008 | 10:10 PM
slowsiEG's Avatar
Default Re: (Schister66)
I already have both of the manifolds, i had looked into the edelbrock's but got a screaming deal on the venom with a75mm TB attached. so as of now those are my options
Old Nov 6, 2008 | 10:15 PM
AdamB18C1EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Neither...get an Edelbrock</TD></TR></TABLE>
im with this guy
Old Nov 6, 2008 | 11:07 PM
RedneckRicer's Avatar
wow thats a first. cause the type r intake doesnt fit a GSR engine.
Old Nov 6, 2008 | 11:41 PM
slowsiEG's Avatar
Default Re: (RedneckRicer)
good call on that one, i was totally have a brain fart. the type r mani was just given too me and i didn't even think about it until now. Thanks for pointing that out guess i will use that venom as i know it fits on the head
Old Nov 7, 2008 | 04:01 AM
joe b's Avatar
Im running my stock gsr manifold with some mild port matching done and am currently running 460whp . A couple of weeks ago i ran 10.9 @ 131 mph . Many people are quick to toss this manifold . Dont under estimate oe parts !
Old Nov 7, 2008 | 05:24 AM
EddieCRX's Avatar
Default Re: Type R intake or Venom (joe b)
I would like to know what people would use as a compromise, y car is UK spec CRX, obviously the ABS pump will not allow for the Victor X so we are a little limited, Type R or Skunk derivative or some totally customer made job.
Not going to junk the ABS, far too good a system for the road.
Idea’s please.
Old Nov 7, 2008 | 11:23 PM
Default Re: Type R intake or Venom (EddieCRX)
Idea’s please.
if you have a car that makes enough power to require a huge plenum intake manifold...why do you want to keep abs...
Old Nov 8, 2008 | 10:45 PM
slowsiEG's Avatar
Default Re: Type R intake or Venom (AdamB18C1EK)
i agree, sorry i didn't specify but this is going in an EG that previously had a boosted H22, i had the S2 intake on that so there was some firewall "modification" that had to be made to make that fit. But Either way ABS is not an issue.
Old Nov 8, 2008 | 10:50 PM
civickiller's Avatar
i got a type r manifold on my lsv gsr head
cut the type r flange off welded a gsr flange
Old Nov 8, 2008 | 11:42 PM
quicksilver1689's Avatar
i ♥ snails
just use the venom, does it allow iacv? if not just settle with a "high" idle, like 1000-1200rpm. Good size plenum.
Old Nov 9, 2008 | 06:41 AM
93CX's Avatar
Default Re: (civickiller)
Wow.. I'm speechless
Old Nov 10, 2008 | 12:35 AM
Default Re: (93CX)
why if u can get everything for less than a type r manifold at its normal price
Old Nov 10, 2008 | 05:36 PM
C.R.E.A.M.*562*'s Avatar
with the edelbrock tb
Old Nov 10, 2008 | 05:45 PM
rota92
Guest
Posts: n/a
Default Re: (C.R.E.A.M.*562*)
GE FTW
Old Nov 10, 2008 | 07:28 PM
jdm inc's Avatar
x2
94SiRswap
Apr 18, 2016 12:55 PM
ThinHoanG
22
Apr 20, 2005 08:39 PM
kotetu
Jun 17, 2003 07:23 AM
vntperformance
May 23, 2002 09:38 AM
