I need help turbo db8 bogging and cant rev pass 3500!!!!! WTF
ok heres the situation the car was running fine before and then it started to bog then we seafomed the car and was running great for a while then it started bogging again..... PLEASE HELP
Heres the setup
Drag turbo kit with master power turbo
aem fuel rail & regulator with holly fuel pump and fmu
msd 6al with msd distributor and coil pack that comes with the msd kit
also no codes please help ASAP!!!!!!!!!
Heres the setup
Moderator
Re: I need help turbo db8 bogging and cant rev pass 3500!!!!! WTF (kauaiboy66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kauaiboy66 »</TD></TR><TR><TD CLASS="quote">ok heres the situation the car was running fine before and then it started to bog then we seafomed the car and was running great for a while then it started bogging again..... PLEASE HELP
Heres the setup
An FMU with fuel regulator (not needed, and is redundant). and probably no missing link or check valves. your map sensor is probably seeing boost when it is not supposed to .
Heres the setup
check your distributor. My old GSR used to bog and then was not able to rev past 3500. Changed the dizzy and all was good. Something easy to look at if you happen to have a spare one around. Good luck
Re: I need help turbo db8 bogging and cant rev pass 3500!!!!! WTF (JAYSEM Society)
My CB7 Accord did the same thing @ 3500 RPM. Turned out to be a bad crank sensor. Changed the dizzy, and was all good. (sorry man, I had to do it lol!)
thanks for the replys but isnt the crank sensor in the dizzy??? but I have a brand new msd pro billet honda distributor and the blaster te blaster sc coil could the dizzy go bad already here's a link what the msd dizzu looks like...
http://www.msdignition.com/Pro....aspx
Re: I need help turbo db8 bogging and cant rev pass 3500!!!!! WTF (Silva Bullit DC4)
Originally Posted by Redline130
Have you tried it with just a stock distributor without any of the MSD parts?
what ecu are you running? are you running a chipped ecu? the programming on the chip could be the problem.
Re: I need help turbo db8 bogging and cant rev pass 3500!!!!! WTF (champ-white-boy)
Do you have ANY idea how rich or lean the engine is getting at that RPM?
Sounds like you're dumping a ton of gasoline in it, which is making massive carbon deposites. Or...you've really hosed your ringlands. Check compression if you can.
GOIN V8 HUNTIN
10-05-2006 10:08 PM
GOIN V8 HUNTIN
09-26-2006 10:26 AM
