Can you identify this Turbo?
There are Turbonetics casting marks on both the cold and hotside of the turbo, however, I'm not sure if you can swap out backing plates. From what I've found, most Turbonetic turbos have a colored billet backing plate where as this one has a backing plate with spokes. The numbers on the cold side read: 30432 E-60, I was told it was probably a T04E 60 trim, but I'm unsure if it's a genuine Turbonetics turbo.
Re: Can you identify this Turbo? (Nisif)
Chinese knock off... E 60 ar cold housing.. Looks like a 5 bolt ex housing... more pics to figure out AR. And yes youll need to measure to figure out trim
I had a VERY similar turbo I bought early on that had the T cast in it, it was a knock off... Chinese manufactrurers are scandelous like that,,, re creating EXACT castings
Re: Can you identify this Turbo? (extralargenog)
30432, 30432e60, ar, bolt, chinese, e60, identify, identifying, knock, measuring, numbers, side, turbo, turbonetic, turbonetics
