Don't start?
Old Nov 8, 2008 | 01:35 PM
inthad's Avatar
Default Turbo install, but doesn't start, please help
I put on the turbo and the car wouldn't start
It cranks and has power. But doesn't try over. Or I don't hear the fuel pump
I have no fuel or spark. The fuel pump don't even come on.
setup
b16a2 obd2
dsm 450cc w/ reistor box
t3/04 50 trim garrett
I can't seem to figure it out
Can it be the obd2 - obd1 conversion harness?
I got the ecu with basemap for my setup from phearable.net
Can it be that the resistor box is wire wrong?
I check the dead end clip and it is good.l
The 4 cut wires goes to the four wires that is from the resistor box. And the red wire from the resistor box goes to all four of the dead end clip. Right?
Or does the resistor box have to be ground?
Modified by inthad at 2:46 PM 11/8/2008
Modified by inthad at 3:01 PM 11/8/2008
Old Nov 9, 2008 | 04:55 AM
inthad's Avatar
Default Re: Turbo install, but doesn't start, please help (inthad)
anybody?
Old Nov 9, 2008 | 05:10 AM
B.'s Avatar
B.
400 HP Club
sorry to say but it could be anything. I'd start with relays and fuses. work your way though it from there. Check all your grounds.
Old Nov 9, 2008 | 08:57 AM
inthad's Avatar
Default Re: Turbo install, but doesn't start, please help (B.)
Ok,
I put the stock injectors on and the ecu. I try to start it, but it doesn't start.
The car was running fine before the turbo installation.
How can it be the relay?
I'm not hearing the fuel pump prime with the stock injectors and ecu.
main Relay can go bad over an turbo installation?
Old Nov 9, 2008 | 09:07 AM
B.'s Avatar
B.
400 HP Club
im not saying thats the problem. but when you cut and re-wire things, you can pop a relay of a fuse no problem. make sure your battery isnt dead, and all your grounds are in check. Its hard to know what the problem is because Im not there to see it. Im just brainstorming general problems.
Old Nov 9, 2008 | 09:32 AM
Tippyman's Avatar
So when you turn the key to on, does the CEL come on for 2 sec and go back off? (You should hear the pump prime while this happens.)
inthad's Avatar
I don't even hear a prime and I don't see an check engine after that. I have nothing but power.
No fuel and spark and thats with stock ecu and stock injectors
i check the fuses, they are good.
How do I check the main relay if its bad?
Where is it located on 99 civic?
Modified by inthad at 5:16 PM 11/9/2008
Old Nov 9, 2008 | 10:09 AM
d16z6turbocivic's Avatar
did you check if the resistor box if it is still good? maybe it can be that =/
Old Nov 9, 2008 | 04:18 PM
inthad's Avatar
Default Re: (d16z6turbocivic)
no i didn't
how do you check if the resistor box is still good?
Old Nov 9, 2008 | 04:24 PM
megomaniac's Avatar
Default Re: (inthad)
do you have a obd1 dizzy? i don't know any thing about b's but i know on a h if you have obd1 ecu you need obd1 dizzy.
Old Nov 9, 2008 | 04:27 PM
inthad's Avatar
Default Re: (megomaniac)
No, I don't have obd1 dizzy.
I have a 99 civic si
I don't think i need one.
I mean, all i have is power and no fuel or spark.
Old Nov 9, 2008 | 10:03 PM
BoostFedDB8's Avatar
Try checking the ground wire that goes on the thermostat housing and see if its loose because it seems like thats the problem.
Old Nov 10, 2008 | 04:04 AM
inthad's Avatar
Default Re: Turbo install, but doesn't start, please help (BoostFedDB8)
Alright, I'll check it out today.
Old Nov 11, 2008 | 02:38 PM
inthad's Avatar
alright this may seems stupid but
If i put back the stock injector and ecu. I remove the resistor box and dsm injectors. Do I connect the deadend clip back together? or can I put an end to it and call it a day.
How do you remove the deadend harness? on 99 civic? obd2. there is no room to work under and above it.
Old Nov 11, 2008 | 05:23 PM
HiProfile's Avatar
The deadend isn't exactly a dead end - one or two wires DOES go back to ground.
On my current EF I have my old EF's harness in it, and all I did to bypass the resistor box was take an older female plug, jump the wires, and plug it in. I had used the plugs that came with the resistor box, so it was easy.
You need to replace the cap on the deadend connector and jump the wires that the resistor box was connected to. To test it before you pull it out, take a multimeter, check the resistance between the injector side of the box and any ground like the motor block. It should have about 7-10 ohms. <U>If you get nothing, you wired it wrong</U>.
Old Nov 11, 2008 | 06:04 PM
inthad's Avatar
Default Re: Turbo install, but doesn't start, please help (HiProfile)
alright, thanks HiProfile
Old Nov 11, 2008 | 08:42 PM
LastGenEK's Avatar
I think this is wrong or i wired mine wrong!!!
Old Nov 11, 2008 | 08:44 PM
LastGenEK's Avatar
Default Re: Turbo install, but doesn't start, please help (LastGenEK)
The four positive chargeg injector wires are suposed to goto the big red wire on the resistor box, then the four black that are left coming out the resistor box goto the inectors
Old Nov 12, 2008 | 02:50 AM
inthad's Avatar
https://honda-tech.com/zerothread?id=1263795
Is where i got my infor
4 ylw/blk injectors wires to 4 blk wire from resistor box then 1 red wire from resistor box to the 4 ylw/blk deadend clip.
Old Nov 15, 2008 | 12:28 PM
inthad's Avatar
I check everything and I come to
that is the
main relay
I installed the main relay but now its still doesn't start
but it does have check engine light now
but the speedo when crazy, it when from 0 to 140 + to the other side of 0.
Whats the cause of this?
Do you have to wire up the stock injectors according to the wires colors?
Does it matter?
What about the deadend clip? Does that matter too?
Modified by inthad at 3:04 PM 11/15/2008
Old Nov 22, 2008 | 01:58 PM
inthad's Avatar
alright, the hard part is done.
the car starts up and good to go.
So what am I suppose to look for? How do I know its fully functional.
is the bov suppose to work then you gas the pedal?
my vac is at like 17
or does it have to have a load?
Old Nov 23, 2008 | 05:30 AM
grndcont's Avatar
what? dude, you might want someone to take a look at your car for you. anyone near this guy?
Old Nov 27, 2008 | 11:52 AM
inthad's Avatar
alright, the car is fine now, drivable
but i don't have any complete downpipe.
I have an half downpipe just for the exhaust to exit under the block.
I have white smoke, coming out, is that normal?
is it because of the downpipe?
is this driveable to the exhaust shop? about 25mins. to get there?
Boost16
Nov 29, 2010 07:03 AM
Psychoteen101
Jul 12, 2009 10:11 PM
94preluder3084
Apr 3, 2007 08:22 AM
Hybrid
May 26, 2003 09:20 AM
