Headgasket? Whats the best?
I have a 400whp gsr. Its gone through two headgaskets now. The first one was just the cometic gasket, no copper spray. That lasted for about 4 months. My second one witch is also the cometic I copper sprayed this one lasted for about the same amount of time. I cant keep going through headgaskets.
Whats the best headgasket?
Copper spray or no?
Engine Details.
18 psi 57 trim t3t4
Victor X manifold
mahle 9.1 pistons
Eagle I beam rods
Block guard
Supertech valve springs rev to 8.5
ARP head studs
Copper spray or no?
Engine Details.
18 psi 57 trim t3t4
Victor X manifold
mahle 9.1 pistons
Eagle I beam rods
Block guard
ARP head studs
Im having the same problem with my headgaskets im putting on the 3rd one this weekend and i dont no why they keep going bad, the head and block are good.Im going to try a thicker head gasket this time.
Mr. Badwrench
Re: (integraturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraturbo »</TD></TR><TR><TD CLASS="quote">Im having the same problem with my headgaskets im putting on the 3rd one this weekend and i dont no why they keep going bad, the head and block are good.Im going to try a thicker head gasket this time.
i have had the same cometic 83mm for 3 years now. there arent many places to be wrong. where is it failing? water intrusion? compression leakage?
oe or cometic.
oe or cometic.
Re: (Humble Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humble Performance »</TD></TR><TR><TD CLASS="quote">I use OEM , make sure your afr's are correct and that you are not running too much timing. </TD></TR></TABLE>
Beat me to it. OEM only, and if you're blowing a lot of headgaskets you are probably having light detonation problems.
Re: (integraturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraturbo »</TD></TR><TR><TD CLASS="quote">If i have a 83mm bore ls motor which oem headgasket should i use?</TD></TR></TABLE>
Contact Golden Eagle, like stated above.
Re: (Redline130)
It seems like everyone is saying OEM. But my tunner says commetic. He is a verry respectable guy in the area. I dont know why this is.
Why would anyone use commetic if OEM is better?
For you guys using the OEM,
How much horsepower is you car making?
How long has the gasket lasted, so far?
Re: (boostedteg4dr)
Originally Posted by Boosted_B_Series
oem ftw
Originally Posted by black_EM1
OEM.
Yes, that's a period.
Originally Posted by WalkerGSR1
Oem.
Originally Posted by TheoneTheycallVille
OEM all the way...
Originally Posted by Schister66
I've only ever run OEM....its all i'd recommend
Originally Posted by Redline130
I've never had any problems with OEM Honda headgaskets.
Re: (garage16.ca)
For you guys using the OEM, or commetic. List the headgasket your using and
Re: (boostedteg4dr)
Maybe your tuner is a Cometic dealer? I'm sure as long as the head and block are prepped right, you will be fine with either gasket.
Re: (Redline130)
I Used OEM No problems
GSR Head and block
8.8 cr, H-beams
t3t04e 10 psi
262
whp
7,000 miles no issues
Honda Everything if i could aford it haha
GSR Head and block
8.8 cr, H-beams
t3t04e 10 psi
262
whp
Re: (boostedteg4dr)
I been only using OEM headgaskets and have never ran into any problems and I even reuse them (only one time) with copper spray. I have a t3/t4 b20vtec with b16 head 381 whp. Been running for 10k miles now
dartonh22
04-27-2008 07:31 AM
