how much power could this make?
Old Nov 2, 2008 | 03:31 PM
thegatekeeper14's Avatar
Default how much power could this make?
my friend plans on building a block and boosting it. he says he wants
b20b1with stock type r head
8.9:1 weisco
eagle rods
ram horn mani with a gt32
and e85
what kind of power could be made on this set up?
Old Nov 2, 2008 | 03:47 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: how much power could this make? (thegatekeeper14)
depends on the injectors and fuel system.
need more specifics.
Old Nov 2, 2008 | 03:48 PM
Default Re: how much power could this make? (boostedcivicsir)
1000cc injectors and a 1000 fuel pump
Old Nov 2, 2008 | 04:27 PM
Specail Ed's Avatar
Six.
Old Nov 2, 2008 | 04:45 PM
Schister66's Avatar
Man U FTW
Default Re: how much power could this make? (Specail Ed)
Which GT32?? There are a few variations of them so more info would really help. I know i ran an STC built GT3255b and made some pretty good power. If its a Shodan turbo, i'm sure you'll have no problem pushin past 400whp. I'd be worried about those stock B20 sleeves...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Specail Ed &raquo;</TD></TR><TR><TD CLASS="quote">Six.</TD></TR></TABLE>
Very close
Old Nov 2, 2008 | 05:08 PM
Specail Ed's Avatar
Default Re: how much power could this make? (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
Very close
I think it's quite generous.
Old Nov 2, 2008 | 05:35 PM
neoc03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegatekeeper14 &raquo;</TD></TR><TR><TD CLASS="quote">1000cc injectors and a 1000 fuel pump</TD></TR></TABLE>
What is a 1000 fuel pump?
Old Nov 2, 2008 | 07:04 PM
Default Re: how much power could this make? (neoc03)
the block is aebs sleeved
the turbo is a stc gt3251e
Old Nov 2, 2008 | 07:38 PM
98vtec's Avatar
moderator emeritus
you are never going to find a straight answer. go to a dyno or look up other peoples builds.
Old Nov 2, 2008 | 07:43 PM
Schister66's Avatar
Man U FTW
PM TheShodan and see if he can give you an idea. He should have records of the dyno testing for that turbo
Old Nov 2, 2008 | 07:48 PM
megomaniac's Avatar
why not a gt35r, seen lots of good dyno sheets on the net.
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neoc03 &raquo;</TD></TR><TR><TD CLASS="quote">
What is a 1000 fuel pump? </TD></TR></TABLE>
i think he meant Aeromotive A1000 pump
Old Nov 2, 2008 | 08:18 PM
Default Re: how much power could this make? (tony413)
how do you guys feel about the stock b20 crankshaft.
thought gt35r but thats atons of cash he said hell do that next with a fatty top mount or sidewinder manifold
Old Nov 2, 2008 | 08:33 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
i think he meant Aeromotive A1000 pump </TD></TR></TABLE>
bwahaha you beat me too it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegatekeeper14 &raquo;</TD></TR><TR><TD CLASS="quote">how do you guys feel about the stock b20 crankshaft</TD></TR></TABLE>
its nice, good old forged honda crank, i would just have it balanced.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by megomaniac &raquo;</TD></TR><TR><TD CLASS="quote">why not a gt35r, seen lots of good dyno sheets on the net. </TD></TR></TABLE>
price, the GT32 is journal bearing.
and to answer the OP's question you should be able to max out the turbo with this setup
Old Nov 2, 2008 | 08:54 PM
TheShodan's Avatar
Moderator
Who'd you get the turbo from? Your screen name doesn't seem familiar.
Old Nov 3, 2008 | 04:57 AM
Default Re: (TheShodan)
ill ask my friend.
so were looking at around 600hp on E?
Old Nov 3, 2008 | 05:14 AM
marcj's Avatar
Default Re: (thegatekeeper14)
i'm guessing 156whp.. but only if it has madd vtec yo
Old Nov 3, 2008 | 05:42 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegatekeeper14 &raquo;</TD></TR><TR><TD CLASS="quote">ill ask my friend.
so were looking at around 600hp on E?</TD></TR></TABLE>
Not on the GT3251...you're looking around 450whp max.
Old Nov 3, 2008 | 07:07 AM
neoc03's Avatar
Cool. Just curious. The hammer was meant for me btw not the OP.
Old Nov 3, 2008 | 09:13 AM
450WHP no i should be able to make more than that.
Old Nov 3, 2008 | 09:31 AM
TheShodan's Avatar
Moderator
No. This turbo's capability is no more than about 400whp maximum. If it is truly a GT3251, it will do only that. That turbo was not designed for top end power, only as a low rpm midrange power setup. Putting a "ramhorn" w/ that static compression will only create disappointment if it is truly a GT3251.
Old Nov 3, 2008 | 09:36 AM
neoc03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">No. This turbo's capability is no more than about 400whp maximum. If it is truly a GT3251, it will do only that. That turbo was not designed for top end power, only as a low rpm midrange power setup. Putting a "ramhorn" w/ that static compression will only create disappointment if it is truly a GT3251.</TD></TR></TABLE>
Limitations are limitations. Once a turbo reaches its peak there is nothing you can do but get a bigger turbo.
Old Nov 3, 2008 | 10:27 AM
srmofo's Avatar
Default Re: (neoc03)
ugghhh....Im so sick of these "how much power will this make" threads....I wish people would just listen.....you design your setup around how much power you want to make, not the other way around
Old Nov 3, 2008 | 10:36 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegatekeeper14 &raquo;</TD></TR><TR><TD CLASS="quote">450WHP no i should be able to make more than that.</TD></TR></TABLE>
Nope...definitely not. The GT3251 is basically a trimmed down 57 trim. It was meant, as TheShodan stated, for quick spool and midrange power. I had another variant of it, the GT3255b, which is a little more geared toward the top end, but still a tad smaller than the 57trim. With the power it made on my setup at 10.5psi, i would have only guessed it to be capable of 435-445whp. Since your turbo is smaller, you will have a hard time breaking 415-425whp. What you need to do is snag a Borg Warner S256. That way you'll be set to make 500+whp. If you need more room, look into the S362.
Old Nov 3, 2008 | 11:22 AM
well that sucks i dunno if i wanna go with a bw turbo i like my garrett alot
