What power should i be expecting??
Old Oct 29, 2008 | 01:23 PM
civic_turbo_wannabe's Avatar
Default What power should i be expecting??
Right i need one good answer for this... i'll list my spec... tell me what power i should be expecting... thanks
what psi?
d16z6
cant remember turbo trim but i will find out if that helps
crower stage 2 turbo cams, springs, retainers
eagle rods, vitara pistons, nippon rings comp is 8.5:1
2.5 bar map sensor
440cc rc injectors
using crome pro to tune
walbro 220 fuel pump
need anymore info?
thanks
Old Oct 29, 2008 | 01:29 PM
Schister66's Avatar
Man U FTW
The injectors limit you to about 300whp. Knowing the turbo is 100% necessary if we're going to make any kind of educated guess.
Old Oct 29, 2008 | 01:30 PM
sleeperbb4's Avatar
Default Re: What power should i be expecting?? (civic_turbo_wannabe)
You won't get any answers worth having without turbo specs posted up.
Old Oct 29, 2008 | 03:39 PM
Default Re: What power should i be expecting?? (sleeperbb4)
i thought the injectors would hold me back. okay. thanks. What injectors do you suggest? although i would be quite happy with 300whp, but i may aswell go all out after rebuilding the engine, right?
Its a t3/t4.... 57 trim A/R .50 i know its deffinately a .50 but i will check hot side tomorrow for sure but i think thats it.
Old Oct 29, 2008 | 04:16 PM
Schister66's Avatar
Man U FTW
Posts like this aren't allowed by the forum rules.
tron_
May 16, 2013 11:22 AM
Guzman.R.M.S
Feb 28, 2011 08:13 PM
untitled
Dec 17, 2004 08:25 AM
ridnmyhonda
Mar 8, 2003 07:53 AM
