A few questions before i start building.
wanted to know how much hp and tq the stock sleeve can hold? I am building the motor and putting it on a big turbo. My goal is 480whp on stock sleeve anything else will be bonus. As far as a tranny what do i have to do to get one that holds what im looking for ??
These are the mods i have listed as of now :
Wiesco 9:0:1 Pistons
Crower Rods
Cosmetic Headgasket
ARP Headstuds
exeddy clutch twin disk
Block Guard
New oil pump
New water pump
Aftermarket oil pan
vavles,springs,retainers
camshafts
cam gears
RC 1000cc injectors
walbro 255lb fuel pump
Fuel return line kit
Fuel rail
Fuel regulator
Now as far as the turbo kit i am trying to do something totally different than everyone else.. I was going to use a full race gt35 turbo kit, but i decided to change it up a little bit.
Borg Warner S362 Turbocharger OR Turbonetics GT-K 550
Custom top mount Turbo manfiold
Tial 44mm wastegate
wastegate dumptube
3" downpipe
HKS SSQV BOV
Custom Intercooler rated 750whp
Custom Intercooler pipings
Oil Line Kit
Vacuum Line Kit
Hardware Kit
Gasket Kit
Silicon Coupler Kit
Hose Clamp Kit
If any1 has any suggestions please go ahead....
Thanks
Modified by itsjdm at 10:38 AM 11/11/2008
Modified by itsjdm at 10:42 AM 11/11/2008
Modified by itsjdm at 10:44 AM 11/11/2008
Modified by itsjdm at 10:57 AM 11/11/2008
Modified by itsjdm at 12:49 PM 11/11/2008
Crower Rods
Cosmetic Headgasket
ARP Headstuds
Block Guard
New oil pump
New water pump
Aftermarket oil pan
camshafts
cam gears
RC 1000cc injectors
Fuel rail
Fuel regulator
Tial 44mm wastegate
wastegate dumptube
3" downpipe
HKS SSQV BOV
Oil Line Kit
Vacuum Line Kit
Hardware Kit
Gasket Kit
Silicon Coupler Kit
Hose Clamp Kit
Thanks
Re: A few questions before i start building. (itsjdm)
First off 480WHP can be obtained with stock sleeves. It all depend on the tune and build to determine how much the sleeves are going to hold. As for my own opinion ditch the block guard because if the motor decides to crack a sleeve it isn't going to do much and the drawback is it may prevent coolant to pass through the motor and cause overheating problems. Other than that the build seems pretty good Post up some pics.
