jdmb16 turbo
Old Oct 31, 2008 | 09:08 AM
jdmb16turbo's Avatar
Default jdmb16 turbo
hey everyone whats up?i wanna give everyone a little info on my setup.im just wondering what numbers i will be looking at when i go get it tune. its a t3t4 turbonetics turbo,450 dsm blue top injectors,walbro 255 furl pump,3inch dp,38mm rev hard wastegate,greddy turbo mani.my motor is a jdm b16 with a gsr trans good setup or not lmk thanks. and is it possible to get at least 330whp on a stock bottom end with a semi built head for a dd
Old Oct 31, 2008 | 09:11 AM
Schister66's Avatar
Man U FTW
Posts like this are not allowed by the rules, but i'll give you a little help this time.
Your injectors are too small for your power goals. 440s will max around 290whp. You should go with 750cc's. Also, since we have no idea what kind of turbo you have, we cant give you any sort of real estimate/ answer. More info would help...
Old Oct 31, 2008 | 09:13 AM
Default Re: (Schister66)
its a turbonetics turbo t3t4 not sure of the trim
Old Oct 31, 2008 | 09:41 AM
Schister66's Avatar
Man U FTW
Well the problem is that there's about 1000 different variations. Regardless it should make your goal, but if you dont have an aftermarket map sensor, you might fall short of making it
Old Oct 31, 2008 | 09:57 AM
forgot to mention i have a 3 bar map
Old Oct 31, 2008 | 12:05 PM
Schister66's Avatar
Man U FTW
Ok...well if you get a set of larger injectors, you should have no problem making your goal.
Eplusz
Mar 20, 2010 11:34 AM
95civhb
Apr 15, 2008 09:21 PM
deeweezy187
Oct 24, 2005 09:27 PM
dk-fabrications
Oct 17, 2004 12:04 AM
Mr.c
18
Jul 8, 2004 02:09 PM
