electronic boost controller help
Old Nov 6, 2008 | 11:34 PM
s4yama's Avatar
Default electronic boost controller help
i have an innovative MSBC, to bad they don't exist anymore, anyway, i know the wastegate sees only pressure but does the solenoid for the controller also see only boost or is it ok to have it's source be off of the IM after the throttle body?
Old Nov 7, 2008 | 04:59 AM
yakuza's Avatar
Default Re: electronic boost controller help (s4yama)
An electronic boost controller will have its own boost/vacuum sensor which should be connected to the same source of vacuum for your wastegate.
Old Nov 7, 2008 | 06:41 AM
HiProfile's Avatar
If its a normally closed [when no power] solenoid like the ems-based EBC's use, vacuum is better. If its normally open like a GM If its normally open, it will pull vacuum when you let off, which will slow the valve between shifts.
I like to get it closed as fast as possible, so i use vac with a NC solenoid. Since its common for extrnal EBC's to use their own sensor and a NO solenoid, I'd use boost only.
Old Nov 7, 2008 | 07:12 AM
s4yama's Avatar
Default Re: electronic boost controller help (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s4yama &raquo;</TD></TR><TR><TD CLASS="quote">i have an innovative MSBC, to bad they don't exist anymore, anyway, i know the wastegate sees only pressure but does the solenoid for the controller also see only boost or is it ok to have it's source be off of the IM after the throttle body? </TD></TR></TABLE>
my MSBC has a manifold sensor, it's supply source can be either the manifold or wastegate depending on which set up you choose to run. i currently have it in the manifold setting. so my sensor is source is the IM. not sure how beneficial it would be to change it to a wastegate signal. although i am fairly new to boosting. thanks for the help so far.
Mugencrxsir1
Feb 22, 2006 10:02 AM
Patron
Jul 23, 2004 07:02 AM
Meet07
Feb 3, 2004 10:45 PM
boostdB16a
Jul 8, 2003 06:10 PM
Mucackus
Apr 26, 2002 08:45 AM
