Stock H22A Turbo - My cylinder compression test results ok?
Well I figured I would do a compression test today since I really do not baby it. So I drove the crap out of it and got home right away to do a compression test. Here are my results - let me know what you guys think ...
Cyl. 1 - 205
Cyl. 2 - 205
Cyl. 3 - 205
Cyl. 4 - 210
Cyl. 5 - ........ Just kiddin! LOL.
I think the numbers are okay - guys who KNOW about this stuff, what do you think?
Cyl. 1 - 205
Cyl. 2 - 205
Cyl. 3 - 205
Cyl. 4 - 210
Re: Stock H22A Turbo - My cylinder compression test results ok? (pcguy760)
On a hot Healthy JDM h22a compression numbers are around 220-230psi... Your numbers are very consistant so i wouldnt worry about anything.
moderator emeritus
the numbers themselves will vary between gauges. You are averaging the same compression in all 4 so you are good to go.
Re: Stock H22A Turbo - My cylinder compression test results ok? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">the numbers themselves will vary between gauges. You are averaging the same compression in all 4 so you are good to go.</TD></TR></TABLE>
Maybe now I should turn the boost controller up to 30 PSI - mad boost with vtak yo!
Looks fine to me.
But i would suggest a leakdown test if you want a more accurate description of the motors health.
