Stupid turbo car
Old Nov 9, 2008 | 11:24 AM
blake22's Avatar
Default Stupid turbo car
Last night i need a boost run on the high way and afterwards i put my car in neutral to coast and it dies. So i started it back up and it wouldn't idle and if it wasn't in gear it died. I popped the hood and there is oil all over the right side of the engine bay. The dip stick was out like 2 inches and oil came out of my breather too. I put oil back in it and it starts but won't idle, it blows smoke out of the valve cover and sounds like a tractor. By the way its a turbo f22b2 accord. HELP PLEASE.
Old Nov 9, 2008 | 11:58 AM
redrim's Avatar
Default Re: Stupid turbo car (blake22)
sounds like you have pieces of motor floating around in............your motor.
buy a new one
Old Nov 9, 2008 | 12:00 PM
black_EM1's Avatar
Community Builder
Community Influencer
Goodbye ringlands.
Old Nov 9, 2008 | 12:29 PM
blake22's Avatar
Default Re: Stupid turbo car (black_EM1)
Yeah thats what i was thinking it happened to my old motor. I broke a 3 inch piece out of the top ringland in cylinder 3 last time.
Old Nov 9, 2008 | 09:45 PM
blinx9900's Avatar
sounds like you need some good positive crankcase ventilation, that could take a good bit of pressure off your rings which would help your ish last longer! but yeah do a compression test, sounds like motor went bye bye...
Old Nov 10, 2008 | 08:02 AM
blake22's Avatar
Default Re: Stupid turbo car (blinx9900)
I just did a compression test and its a goner. It was 140, 40, 30, 135
Old Nov 10, 2008 | 08:17 AM
98vtec's Avatar
moderator emeritus
do you have anything to help vent the crankcase or is it all factory?
Old Nov 10, 2008 | 08:37 AM
marcj's Avatar
Default Re: Stupid turbo car (98vtec)
both cylinders at the same time? sounds like you got a bad batch of gas and it leaned out..
Old Nov 10, 2008 | 09:44 AM
blake22's Avatar
Default Re: Stupid turbo car (marcj)
Yeah im going to get a catch can and get retuned.
Old Nov 10, 2008 | 10:55 AM
98vtec's Avatar
moderator emeritus
a catch can is not a vent.
Old Nov 10, 2008 | 01:48 PM
accord_raffi's Avatar
please help explaining cuz i need to do an oil catch can and relieve pressure too
Old Nov 10, 2008 | 02:50 PM
96 GSR-T's Avatar
I am pretty sure he was refering to the breather catch can setups and not just a box with a tube attached.
Old Nov 11, 2008 | 08:32 AM
blake22's Avatar
Default Re: Stupid turbo car (96 GSR-T)
Could this be a blown headgasket since the two inside cylinders are really low and the outside ones are ok.
Old Nov 11, 2008 | 02:37 PM
dahmuno's Avatar
wow i have a f22b2 95 prelude, and the oil dipstick is all floppy and it has a massive gargantuan oil leak from the front crank seal..
mine has the wrong power steering pump on it and the screw is missing from the dipstick assembly,,,
so thats why hopefully, it just dumps oil but doesnt have a problem running
that kinda scares me tho, i may just wanna swap to my f22a1 instead, but i have to buy a bunch of crap just to swap itz.
Old Nov 11, 2008 | 03:21 PM
CoreyR's Avatar
if it was a headgasket you wouldnt have oil spraying all over the engine bay. cylinders 2 and 3 have the least amount of cooling around them therefore they run hotter and are more prone to detonation. a nice hard pull on the highway on a cool night with less then perfect tune is probably the culprit
Old Nov 11, 2008 | 05:15 PM
HiProfile's Avatar
Default Re: Stupid turbo car (dahmuno)
Blowing a stock-piston motor shouldn't have any effect on your decision. People blow up built gsr's with crappy tunes too, it doesn't mean the gsr is a bad motor. He just broke the ringlands, which will happen with any stock honda if you get enough detonation from a risky tune.
You are always taking a risk with stock rods/pistons, no question.
Old Nov 11, 2008 | 05:41 PM
fatboy1185's Avatar
Big Cat
Default Re: Stupid turbo car (HiProfile)
head lift. should of used arp bolts and put some breather holes on your valve cover
Old Nov 12, 2008 | 06:53 AM
blake22's Avatar
Default Re: Stupid turbo car (fatboy1185)
I have arp headstuds.
Old Nov 12, 2008 | 12:00 PM
dahmuno's Avatar
what boost was you running, it may have spiked on you.
also, how long have you been running boost on this motor?
how many miles on the engine?
just curious
Old Nov 12, 2008 | 05:52 PM
blake22's Avatar
I was running 8 pounds and ive been running it about 6 months. It is a rebuilt engine with like 6,000 on it.
Old Nov 12, 2008 | 06:03 PM
mr.sky's Avatar
read this:
https://honda-tech.com/zerothread?id=1199935
hammerj2
Mar 18, 2010 06:24 AM
CRXdan
Oct 13, 2005 08:34 PM
kickz
Aug 8, 2002 09:37 PM
b18b25psi
Jul 30, 2002 11:16 AM
X2BOARD
Jan 14, 2002 06:04 PM
