b16a turbo with itr cams??
Hello all, I have itr cams. Can I use it with my b16a turbo?
and this is my following parts:
- 81.5 mm stock sleeves
- Ross pistons 9.3:1 compression
- Eagle connecting rods
- Golden Eagle Block Guard
- Skunk2 intake manifold with 65mm tp
- FIC injectors 1050cc
- Aeromotive Fuel Pressure Regulator
- 255 hp walbro intank
- MSD blaster 3 coil
- Hondata S300 with 4 bar map sensor
- Garrett t3/t4 60-1/.63 stage 3 with 2.5" downpip
So. is it possible that I get more horse power from itr cams than b16a cams. and if i used it is necessary to have Dual Spring and Retainer Kit
thanks for any help
thanks for any help
Re: b16a turbo with itr cams?? (azeez)
..If you do some research, you will find tons of threads on type R cams VS B16. but to answer your question, yes. they will make more power. and def. change your springs and retainers.
Re: b16a turbo with itr cams?? (boostfeen)
I would get the typer springs clips and retainers if your getting the cams. They're a more aggressive cam and would be rough on the b16 springs, and it's not worth having to go back and re-do it all cause you took a short cut. You'll see more power but i'd def. work on getting your car retuned a bit to recieve the full effects of the cams. GSR cams will yield more power as well and are cheaper.
Re: b16a turbo with itr cams?? (Leland)
I mean int/gsr (b18c) cams not itr type R cams
Jdmdelsolb16a
14
04-27-2011 05:21 PM
