Running to rich.........
Old Feb 6, 2005 | 10:29 AM
504tuner's Avatar
Default Running to rich.........
I am runnning 8psi on a turboed b16a2 in a 97 hatch and my air fuel ratio reads that everything is okay but you can smell alot of fuel through the exhaust and in the oil on the dip stick. What do i do to fix this problem? I also have a vfac any help is aprectated....
Old Feb 6, 2005 | 12:04 PM
f22b2tdave's Avatar
Default Re: Running to rich......... (504tuner)
its not good if your dipstick smells like gas. bad ring seal = blowby
blowby + running rich = gassy smell = bad ring seal....yeah
Old Feb 6, 2005 | 12:46 PM
TxTuner
Guest
Posts: n/a
Default Re: Running to rich......... (f22b2tdave)
Just curious... ring-seal???
Old Feb 6, 2005 | 02:24 PM
TxTuner
Guest
Posts: n/a
Default Re: Running to rich......... (TxTuner)
TTT
Old Feb 6, 2005 | 02:27 PM
wantboost's Avatar
Who is Mr Robot?
ring seal = piston rings sealing to the cylinder wall
Old Feb 6, 2005 | 02:45 PM
TxTuner
Guest
Posts: n/a
Default Re: Running to rich......... (wantboost)
gotcha
Old Feb 6, 2005 | 04:02 PM
504tuner's Avatar
how hard is it to fix that.... can i do it myself.....
Old Feb 6, 2005 | 04:07 PM
ProjectDarkBlack's Avatar
this is pretty basic info, you should have took more time to research what you are doing before you built/bought a boosted car. To fix this you have to pull the engine block apart, hone the cyclinders, and replace the piston rings. You cant do it yourself and it is expensive, depending on who you know
Old Feb 6, 2005 | 06:05 PM
boostmywankle's Avatar
Default Re: Running to rich......... (ProjectDarkBlack)
eh.....you can installing piston rings urself! lol. well maybe u cant but someone who is educated with motors can
Old Feb 6, 2005 | 06:36 PM
J337_UNIT's Avatar
Default Re: Running to rich......... (96teggyls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggyls &raquo;</TD></TR><TR><TD CLASS="quote">eh.....you can installing piston rings urself! lol. well maybe u cant but someone who is educated with motors can </TD></TR></TABLE>
before you assume anything as far as poor ring seal... do a compression test.. if you come back with positive results then its not the ring seal. Plus, blowby results usually in white smoke coming out of the exhaust and through the valve cover nipple
Old Feb 8, 2005 | 10:33 AM
504tuner's Avatar
Default Re: Running to rich......... (J337_UNIT)
it blows out black smoke and not white...... i don't think that it is the ring seal any other ideas....
Old Feb 8, 2005 | 10:39 AM
you can intsall cast iron rings yourself if your cylinder walls are decent, but i would not ever replace any rings with cast iron. Put in chrome rings without having the cylinder walls honed and they will probably never seat right
Old Feb 8, 2005 | 05:25 PM
504tuner's Avatar
thanks for the help..... we are goin to try and see what we can do... we have the tools and a place to do it so we are going to probally give it a shot...
DumpdEJ6
Apr 25, 2010 08:35 PM
( o )( o )
11
Jan 30, 2008 03:53 PM
Fatty_1775
Feb 13, 2003 06:43 PM
B00ST2nR
Aug 27, 2002 10:59 PM
badCRX
Jun 24, 2002 08:48 PM
