Easiest way to hook up a catch can setup
Old Feb 3, 2005 | 03:11 PM
BlueShadow's Avatar
Default Easiest way to hook up a catch can setup
EDITED:
hey guys,
I wanted to bring this thread back up one more time. I read dashers catch can thread and I have a good understanding now on how everything is supposed to hook up together. I just need your guys opinions on the actual hardware I will be using. I already have a Endyn catch can with SS braided fittings, and my Moroso tank p/n 85465. Dasher already looked at my setup and he said it looks good. But I just wanted to make sure I ordered the correct fittings. Also, in case anybody was wondering I dont plan on using slashcut tubing to create a vacuum in the cans.
Here is what I'm gonna do:
BLOCK:
leave PCV black box in place, plug 2 top ports
plug up IM port and engine block port that went to top of PCV black box
take out allen plugs on back of B18C block and replace with Honda port fittings
1/2" inner dia clear nylon reinforced tubing from 2 ports on Endyn catch can to 2 ports on the back of the block
3/8" inner dia clear nylon reinforced tubing for drain line
VALVE COVER
-12AN to -10AN reducer cause the Moroso can has a -12AN outlet PIC
-10AN straight barbed fitting to screw onto -12AN to -10AN reducer on Moroso can PIC
-10AN aluminum weld-on bung to be welded to the front of valve cover PIC
-10AN 45 degree barbed fitting to screw onto weld on bung PIC
1/2" inner dia clear nylon reinforced tubing to go between valve cover and Moroso can
I just needed your guys input on the parts for the valve cover. I included pics in the links, I just needed to know if they are the correct barbed fittings. Also, do you guys know if summitracing or jegs has 1/2" and 3/8" diameter clear nylon reinforced hose for use with oil and high temps?
TIA
Modified by BlueShadow at 11:41 AM 7/17/2005
Old Feb 3, 2005 | 03:35 PM
WREKONIZE V8 KLR's Avatar
Default Re: Easiest way to hook up a catch can setup (BlueShadow)
this is how i did mine
keep the stock one were it is, disconnct the line from the im to the black box, run the top catch can hose to theblack box and the lower one to the im. my catch can is baffled and seald closed though?
Old Feb 3, 2005 | 04:52 PM
sounds good to me
Old Jul 17, 2005 | 10:42 AM
BlueShadow's Avatar
Default Re: Easiest way to hook up a catch can setup (WREKONIZE V8 KLR)
bump, edited the first post
92integraVTECgsr
24
Feb 15, 2018 10:29 AM
incubusboy87
Aug 13, 2007 09:02 PM
highmilehatch
Jul 7, 2006 05:38 AM
HamiltonRex
Dec 30, 2005 09:56 PM
