O2 simulator
Old Feb 3, 2005 | 07:47 AM
Hyaboosta's Avatar
Default O2 simulator
Does anyone know where I can get an 02 sim for a good price for obd2? Or if there is a way to get around it? here are pics of the dp
Old Feb 3, 2005 | 09:34 AM
richeybrooks's Avatar
Default Re: O2 simulator (Hyaboosta)
i have one i mad it my self. ill send it to you for 25$ PM me
Old Feb 3, 2005 | 09:47 AM
PrettyLude's Avatar
mkteller.com
try and get a caspers electronics one though, its plug and play
Old Feb 3, 2005 | 09:57 AM
D-tuned's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">mkteller.com
try and get a caspers electronics one though, its plug and play</TD></TR></TABLE>
Old Feb 3, 2005 | 10:00 AM
DaX's Avatar
DaX
Loved
Community Favorite
https://www.casperselectronics...honda
Old Feb 3, 2005 | 10:45 AM
SOHC_MShue's Avatar
i don't think you really need one. when I was still obd2 I had installed a test pipe and threw a cel, but the car never ran any different with the cel.
Old Feb 3, 2005 | 10:57 AM
sharkcohen's Avatar
Default Re: O2 simulator (SOHC_MShue)
It wouldn't run any different. The secondary O2 sensor has nothing to do with fueling. A trouble code related to the secondary sensor will not cause the car to run in open loop. Having the light on all the time is annoying, though.
Old Feb 3, 2005 | 11:12 AM
Hyaboosta's Avatar
Default Re: O2 simulator (sharkcohen)
it wouldn't effect the fuel at all? I am going to run emanage and boost. I thought since all the sensors aren't working it would throw it into open loop?
Old Feb 3, 2005 | 11:17 AM
sharkcohen's Avatar
Not all trouble codes trigger open loop.
Old Feb 3, 2005 | 11:53 AM
Hyaboosta's Avatar
but my car is throwing a cel for the secondary o2 sensor now becasue my cat is gutted
Old Feb 3, 2005 | 11:59 AM
sharkcohen's Avatar
That's expected.
Old Feb 3, 2005 | 12:01 PM
beepy's Avatar
The way to solve that problem is to take the bulb out of the CEL.
Old Feb 3, 2005 | 12:02 PM
Hyaboosta's Avatar
thanks for the info I thought it would affect it. I'll install the kit this weekend and get the 02 sm next week so I can tell when there is a new cell I should worry about.
Old Feb 3, 2005 | 12:05 PM
Evanmb44's Avatar
this is what i did and it works fine
let the secondary o2 sensor be open to the atmosphere.
i just ziptied mine up out of the way and it costs nothing.
and no CEL
if you dont want to spend the money on an o2 simulator then use the handy ziptie
Old Feb 3, 2005 | 12:12 PM
Hyaboosta's Avatar
Default Re: O2 simulator (Evanmb44)
^ what year car do you have? obd1?
Old Feb 3, 2005 | 03:19 PM
DaX's Avatar
DaX
Loved
Community Favorite
By the look of his sig, he's got a 97 something...so he's OBD-II. I don't think any OBD-1 cars came with a secondary o2 sensor anyhow.
Old Feb 3, 2005 | 03:33 PM
ki11a8ee's Avatar
Default Re: (DaX)
what if u dont have the plug and play feature and u have to wire it in?? i have missing wrining for the 2nd o2?
what would u do?
thanks
Modified by ki11a8ee at 3:40 AM 2/4/2005
Old Feb 3, 2005 | 10:03 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hyaboosta &raquo;</TD></TR><TR><TD CLASS="quote">it wouldn't effect the fuel at all? I am going to run emanage and boost. I thought since all the sensors aren't working it would throw it into open loop?</TD></TR></TABLE>
screw closed loop anyways. I run my car in open loop all the time. Its much safer for turbo imo. Just make sure you tune the partial throttle maps and you will be fine. I'm not sure if you can do anything about this with obd2 and emanage though .
Old Feb 4, 2005 | 02:53 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evanmb44 &raquo;</TD></TR><TR><TD CLASS="quote">this is what i did and it works fine
and no CEL
if you dont want to spend the money on an o2 simulator then use the handy ziptie</TD></TR></TABLE>
Bingo. Works like a charm. Only real problem with doing that, though, is finding something likely to stuff into the secondary O2 bung... oh, dear, how ever shall we manage???
Old Feb 4, 2005 | 05:26 AM
TurboLude97's Avatar
Default Re: O2 simulator (J. Davis)
if you want to get rid of the cel w/o a simulator all you have to do is cut the secondary O2 sensor signal wire going to the ecu... Make sure you keep the sensor plugged in because the heater has to work, if you dont want it in the exhaust just put some aluminium foil around it and zip tie it to the heat shield. This is how I did mine and never got a CEL.
Old Feb 4, 2005 | 06:21 AM
Hyaboosta's Avatar
Default Re: O2 simulator (TurboLude97)
So everyone agrees that If i just wrap it up and pull it from the bung it will be ok? what should I use to plug the whole then?
Old Feb 4, 2005 | 06:30 AM
SOHC_MShue's Avatar
http://www.innovatemotorsports...age=1 a plug
Old Feb 4, 2005 | 07:53 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">http://www.innovatemotorsports...age=1 a plug</TD></TR></TABLE>
ATPturbo.com also sells an o2 bung block off bolt.
Old Feb 4, 2005 | 08:47 AM
Hyaboosta's Avatar
Default Re: O2 simulator (DaX)
nice. thanks alot for the help everyone
Tiger_Si
Aug 16, 2008 09:34 AM
beastman@
Jul 10, 2008 08:53 AM
gulftiresinc
Sep 18, 2004 09:55 AM
CHEETAH
Honda S2000
Jun 2, 2004 07:31 AM
gsrbruin
Jun 25, 2003 09:15 AM
