V-AFC Hack and JRSC
Old Feb 7, 2005 | 07:30 AM
1strdko's Avatar
Default V-AFC Hack and JRSC
Will the V-AFC hack work with a JRSC (450 cc with V-AFC)? Do I need a FMU or can I just use the JR BTC and the V-AFC? I want to pass emissions here in Tucson, Arizona and will use the V-AFC with stock injectors then tune it with the 450 DSM injectors after I pass emmisions.
Please help and all coments are appreciated!
Old Feb 7, 2005 | 07:31 AM
93turbo16's Avatar
You can use it.. but why not go with uberdata and get rid of the vafc and a BTC... it will do both for less money.
Old Feb 7, 2005 | 08:30 AM
SPOOLINmatt's Avatar
Default Re: (93turbo16)
jrsc doesnt require a hack...because its got the map sensor before the boost pressure so the map always reads vacuum no matter if your boosting 5 or 20psi. the stock inj can handle 6psi all day long...if you go up to 10psi, i think 450 would still be to large...maybe somewhere like 310 would be good.
Green94GSR
Aug 28, 2005 12:21 PM
EX R8ED
Sep 8, 2004 12:14 PM
Westsideboy
Apr 22, 2004 08:21 PM
quik2kSi
Jul 17, 2003 07:09 PM
